AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Berkline Accessory Mount - Universal?
post #1 of 2
Sorry if this is a dumb question, I wasn't able to search out an answer. I recently picked up a Berkline Power Recliner for cheap (not sure the model; doesn't have papers or markings I can find), and it's got these table/accessory mounts on the arms just past the cup holders. On other chairs (Palliser in particular), there seem to be several accessories available for this mount.
Does anyone know if these mounts are universal, or if they are specific to each manufacturer? The mount is a metal disc with a hole in the center for a pole to be slotted into.
I'd like to order an iPad mount from somewhere, something like this http://www.stargatecinema.com/Palliser-iPad-Tablet-Holder-pr-93051.html, but I want to be sure first.
Edited by AaronHal - 7/16/12 at 10:20am
post #2 of 2
AaronHal,
Yes, the Palliser iPad Holder should fit your Berkline model chair. Palliser uses the same type of system on their tray tables and iPad holders. The metal cylinders used by each manufacturer are very similar and usually the same diameter. If you can measure the inside diameter of the small metal cylinder that gets pressed down when you insert an accessory we can verify for you.
