Originally Posted by
AV-Freak
Last weekend I calibrated a Samsung LED tv of a friend.
Worked without a problem. But how can you save the found daylight and night settings?
Usually (LG, Panasonic, ..) you have two profiles where you can store them and switch between them.
But how is this done with Samsung tvs?
There are CAL-DAY and CAL-NIGHT modes that can be activated in the service menu. In the SM, you select Expert and then turn the N/D ADJUST item ON. There is also a FIX option that locks the settings (OFF, ON, and FIX being the three choices for this item) and the SOURCE item lets you either use separate settings for each source (CURRENT) or the same settings for everything (ALL). Be careful in the SM and only use the up and down arrow buttons on the TV remote to scroll down to the Expert section of the SM and then press enter to access that menu. Then select the item you want to adjust by highlighting it and pressing enter and then the right arrow or left arrow buttons can be used to change the value of the item. You can press the menu button to go back a menu and the power button to exit the SM.
Since the left/right arrow buttons change values in the SM, don't trying using them to navigate through the menus (many have bricked their sets this way).
