http://www.mediasmartserver.net/2012/07/16/med1000x3d-high-definition-3d-multimedia-player-announced/
Just announced:
Just announced:
Mede8er MD1000X3D Landing Soon
The long awaited 3D Multimedia player from Mede8er is landing soon.
Mede8er has achieved the ultimate balance in design and functionality with the all new MED1000X3D High Definition 3D Multimedia Player. It may look like an alien spaceship from outer space, but we can assure you that it was designed and developed by very passionate people right here on Earth.
Quick and simple is the Mede8er way. No need to install special brackets etc. Create a bookshelf of Hard Drive storage and you will never be short of space again.
Ergonomic IR remote with full active backlighting and user programmable function button. It is normally very difficult to see the remote buttons in a dark TV Room. If you are wearing 3D glasses Its near impossible. The MED1000X3D remote with active back lighting makes it so simple without the need for removing the glasses every time you want to use the remote.
3D VIDEO Support – Full BDISO, Side by Side, Top & Bottom, Frame Sequential, Frame Packing
Main Features
Full 3D – HDMI 1.4 – Play 3D BD-ISO
Complete Aluminium Die Cast Casing – Fanless Design
Mede8er Xbay – Easy Hard Drive Change – Up to 3 TB
Active Backlit Remote with Self Learning Hot Button
Mede8er Developed Movie & Music JukeBox – Database Driven
Web Services, YouTube XL , Web Browser
Built in Mede8er Favourites Manager
Community Skins and Ways Backdrop Customization
HD Audio – 7.1 DTSMA & Dolby True HD
Fast USB 3.0 & Gbit Network Port
0dB Noise excluding internal Hard Drive
Features
Music Jukebox Local and Network support
Built in View Manager
Compatible with MAC HFS+ USB Drives
Movie XML Med Data in Media Library
Video JukeBox XML Search
All Aluminium Body – Fanless Design
Hard Drive Spin Down Function
Alpha Search in Media Library
Xbay – easy Hard Drive swop
Internal Hard Drive up to 3TB
Built in Favourites Manager
Internet Media Streams
Social Media
Watched Indicator
Built in Web Browser
Optional WiFi USB / PCIE
Internet Radio (Shoutcast)
Full Parental control on Folders
SD Card / Sony Pro Duo Card Slot
Samba Server – NAS storage
Photo slide show with background music
Subtitle: SRT, SSA, SUB, SMI format
Network – Ethernet 10/100/1000 Mbps port
Specifications
Processor: RTD1186 • 750Mhz • 512 SLC Flash • 512 DDR3 SDRAM
Video Formats Supported: AVI / BDMV Light / BDISO Light / MKV / TS / TP / TRP / M2TS / MPG / MP4 / MOV / M4V / VOB / ISO / IFO / DAT / WMV / ASF / RM / RMVB / FLV resolution up to 720p / 1080i / 1080p
3D Video: 3D BDISO, Side by Side, Top & Bottom, Frame Sequential, Frame Packing
Video Codecs Supported: MPEG-1-2 / MPEG-4 SP /ASP /AVC (H.264) / XviD / DivX / WMV9 (VC-1) / RealVideo 8/9/10 (up to 720P)
Audio Codec Supported: Mp3 / Mp2 / OGG Vorbis / PCM / LPCM / AAC / RA / Dolby True HD – DTS MA Passthrough on HDMI / AC3 – DTS 5.1 / FLAC up to 24bit 192Khz / WAV / WMA Standard (DRM, & Advanced Profile not supported)
Photo format Supported: JPEG, BMP, GIF, TIFF, PNG File System Supported: FAT32, NTFS, HFS+ (Mac) Video output resolution: NTSC, PAL, 480p, 576p, 720p, 1080i, 1080p, 1080p 24hz Input /
Outputs: HDMI 1.4 • Component Video • Composite Video • Stereo RCA • SD • SDHC • Sony Pro Duo Card Slot • SPDIF Optical • Co-Ax Digital • Slave Port USB 3.0, HOST Port x 2 USB 2.0 • IR Jack
Optional WiFi: MED10WFB or MED20PCIE (WiFi is optional unless otherwise stated on the packaging)
Optional Hard Drive: Internal Hard Drive is optional unless otherwise stated on the packaging.
Contents: MED1000X3D, RC, 2 x AA Batteries, AC Adapter, HDMI 1.4 Cable, AV Cable, USB3.0 Cable, HDD Securing Screws.
Specifications subject to change without notice.
DTS, DTS-HD, the Symbol, & DTS or DTS-HD and the Symbol together are registered trademarks of DTS, Inc. © DTS, Inc.
Main Features
Features
Social Media
Watched Indicator
Specifications
