Damian commented that it's the non-Android firmware for this player that Mede8er could customize.Originally Posted by halfelite
I swore I read somewhere It had a custom self built firmware but I for the life of me cant find it anymore. If they are making a complete firmware and no longer using realtek turnkey it could mean fixed but also could mean lots of other things are broke, Might have to wait to see on this unit.
Via hdlandforum (French), some initial impressions were posted:
- The menus are much nicer than before. It's a good point.
- BD Lite mode does not work well and generates bugs in particular network. When disabled, all falls into place.
- The Auto framerate not working well. The 23.976 Hz is well managed but the DVD NTSC saccadent.
- The network works fine, including the 3D BS ISO.
- The remote is not bad but some times, the buttons are pressed. Additional Power button located on the left side can not activate accident ... Not glop! For cons, the shot of backlit keys, too cool!
- Web applications work quite well and are pretty fast including Internet browser.
- The box is quite heavy. It smells seriously.
- Access times are extremely short on including BD ISO. Resume playback works well on all files.
- The subtitles are displayed well and cleanly.
- The DVD upscaling works particularly well, including on NTSC DVD.
- The placement system of internal hard drive is original and practical.
- The connection is ultra complete.
Overall it's a good machine but the firmware is not yet finalized. But there is still one month to Mede8er to improve the firmware before the release.
Above is via Google Translate. Good to hear 23.976 "well managed", but author doesn't say whether it's fine for 2D and 3D film-based material. BD-lite bugs are concerning as it would be needed for playlist select for 2D and 3D BD-ISO's. Hopefully, Mede8er is actively looking here (or will be) and at other forums in order to release updated firmwares quickly.
. HiMedia and Micca players have NOT fixed this. Maybe this is a Realtek issue as I don't see forced subs supported in any 1185 and 1186 players to date.
