AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › MED1000X3D High Definition 3D Multimedia Player
MED1000X3D High Definition 3D Multimedia Player - Page 30
post #871 of 888
Originally Posted by csrini1 View Post
I asked if and when it goes on sale, not the regular price,
Good luck. I've never seen them on sale. You might be able to buy a used one for less.
post #872 of 888
Originally Posted by vinvin View Post
Hi,
First forgive my language … I’m french.
Second, maybe this is not the right place to post this question : feel free to move it to the right topic then.
Until now, I was using an internal HDD in my MED1000X3D (with 1.0.5 firmware) that worked well.
Instead, I try for several days now to connect my Mede8er to my PC in order to directly watch movies and pictures stored on my PC (Windows 7 - 64).
I have read many topics on this forum but I still can’t see my shared folders in the “media library”, “network” (or “DHCP” ) menu of the Mede8er, no matter what (I only see the “MED1000X3D” and my “internet box” folders).
I can access to internet (youtube…) through the Mede8er.
In the same time, I see the Mede8er on my PC , when checking the “network”.
(I tried the “Mede8er Share Manager”)
I thought it was because of the switch (Netgear GS105E) I use between the PC and the Mede8er (in order to plug the internet cable) so I’ve tried to connect directly those two, through a single RJ45 cable, without any other devices, nor internet.
But it’s still the same…
For the moment, I try to use Samba (without any passwords set on the Mede8er Samba menu),as I only watch 2D.
The mede8er LAN menu is set in DHCP.
On my PC, the IP address is set “automatic” in the options of the network controller card (do I have to choose a specific and constant IP ?).
In the Samba menu of the Mede8er, I can change the “workgroup” name to another one : I have tried to enter my PC “name” (which looks like “XXX-PC”)…still nothing.
Maybe the workgroup on my PC is not named “WORKGROUP” ? How and where can I check this ?
I have seen on the forum that I can manually add shortcuts to my PC shared folders but I have to enter its IP address: how can I do that because it’s changing each time, being set to “automatic IP” ?
Also, do I have to create a “homegroup” in windows ?
And on my PC, I only use an administrator session (with my name but no password) : do I have to enter this information anywhere ?
This is driving me mad, thank you in advance for your help !
Vincent
At laaaaaast !!!!!!!!!
I have found the answer : I don't know why but in the options of my realtek network controler, the first three options :
"client for microsoft networks"
"Qos packet scheduler"
"File and printer sharing for microsoft networks"
were unchecked.
I've checked them all and : now it works !
Maybe the three are not necessary but only one of them ? I don't know.
Anyway, thanks for helping !
post #873 of 888
were unchecked.
That's good to know. I'll make a mental note of this. I didn't think that would make a difference, but Win 7 is weird with network shares.
post #874 of 888
new firmware 20 and 22 march
Install X3D_Series_V2BETA_22March2013
Install using the Emergency Procedure
Changelog V2.0.0 - 22March 2013
1. Dev: net api, use async mode to start audio playback to avoid crashing...
2. Dev: net api, play command added support for multiple tags musicdir and moviedir.
3. Dev: adjust the position of options in MENU for "Add to Jukebox+" and "Add to Favorites".
3. Dev: will keep in movie jukebox view when discreet off.
4. Dev: dutch strings updated.
5. Dev: added option "Empty" to clear the content of Jukebox+.
Changelog V2.0.0 - 20March 2013
1. Fixed - crash on id3tag of mp3 file.
2. Fixed - Lock movie in JukeBox Plus
3. Fixed - Play Music Folder functionality
4. Fixed - Black Bar on Flickr screensaver.
5. Fixed - FAT 32 USB drive/partition names are shown with a ÿ-character in front of the drive name.
6. Fixed - in X3_GUI.xml does not change the text colour of Favourites.
7. Fixed - Play music folder in net api crash.
8. Dev - JukeBox Plus not added to NET API
9. Dev - 'Add to JukeBox' will now copy .t and .folder.locked files to JukeBox Plus folder.
10. Dev - Added string for ADD_TO_MUSIC_JUKEBOX.
11. Dev - when doing a discreet off command X3D will firstly return to Home Screen and then action the command.
12. Dev - net api, when play single music file, will try to list all the music files inside the folder.
13. Dev - net api, enabled normal share in favorites.
14. Dev - net api, added support for time jump in movie playback.
15. Dev - net api, added new param for command status: movietime, musictime, musicinfo, musiclist.
post #875 of 888
new firmware version
Changelog V2.0.0 - 26March 2013
1. Fixed - net api, rc menu is not working correctly in favorites/ jukebox.
2. Fixed - BDMV folder would not be added to JukeBox +.
3. Fixed - ext subtitle when playing filelink of BDMV folder.
4. Dev - added setup option "Multiple Video Play".
5. Dev - separated the settings for "Show Movie Info" in FileManager and MovieJukebox.
6. Dev: added OSD language ENGLISH(US).
7. Dev: improved the subtitle outline display.
8. Dev: net api, added a thumb node in music jukebox json file for each folder.
http://www.mede8erforum.com/index.php/topic,10949.0.html
post #876 of 888
Some update images of M8 JukeBox iPad App for Mede8er X3D Series.
Mede8er1
post #877 of 888
When using the Media Library to look at what is on the internal hard drive, is there a way to scroll a page/screen at a time instead of one file at a time with the remote control?
Also, is the add-on MEDX2KEY USB WIRELESS KEYBOARD able to scroll a page at a time?
post #878 of 888
I know it's possible. I do it all the time with my Harmony remote. Sorry I don't know which keys on the included remote do page up/down.
post #879 of 888
Originally Posted by igboo View Post
I know it's possible. I do it all the time with my Harmony remote..
Which Harmony remote do you use?
post #880 of 888
I have the 880. Page up/down is the up and down arrows right below the directional pad.
post #881 of 888
Thanks for the info igboo.
post #882 of 888
Mede8er V2 and Absolute App on track for May release.
Mede8er1
post #883 of 888
Any chance of getting yupptv app also on this box? http://www.yupptv.com/.
post #884 of 888
post #885 of 888
Online Mede8er Product Leaflet
http://www.mede8er.org/
Mede8er1
post #886 of 888
Edited by mede8er1 - 5/17/13 at 9:02am
post #887 of 888
May 21... can't wait. Will there be guides on setting up? From screenshots, it appears Y2M output is supported; hopefully TVRename output as well for TV shows.
post #888 of 888
Here is the User Guide for Apsolute App using NET API on X3d
http://www.mede8erforum.com/index.php/topic,11337.msg73355.html#msg73355
Mede8er1
