AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › *Official* Mede8er X3D (1000 | 800 | 600) Streamer Thread
*Official* Mede8er X3D (1000 | 800 | 600) Streamer Thread - Page 25
post #721 of 1300
Originally Posted by ScottFern View Post
I am a newbie 1000X3D owner and just got done setting it up with all the cover art for my movie library and all this talk of V2 of the firmware has peaked my interest. The 1000X3D in my opinion is 85% of the way there and just needs some tweaks in the jukebox and overall presentation.
Wondering if any of the items from my wish list are included in the v2 update?
- Some way to identify if a move is - director's cut, extended, or unrated edition.
- Some way to sort by genre without me having to create genre folders and separate my movies manually. Which is silly anyway because some movies are more than a single genre.
- Some way to get more movies displayed on a single page than the maximum shown with "movies mode".
- Some way to better display TV shows and the individual episodes. (I admit I have not tinkered with this one yet but I hear from lots of people there is something left to be desired here)
I do have to say overall I am very satisfied with this player. It just needs a few tweaks to get to the top IMO!
Regarding the TV Shows option, this is the area that is sorely lacking. You either need to put each individual episode in its own folder (absolutely horrible idea) or there is the basic TV Show view mode (not part of the jukebox). You can see this in my review:
http://www.mediasmartserver.net/2012/04/09/review-mede8er-med500x2/
post #722 of 1300
Originally Posted by dbone1026 View Post
No, no new players support this... and no Realtek players (old or new)
So what is the expected behavior when you launch a BD ISO? Straight to the movie? What if you want access so special features or alternate cut (for example)?
post #723 of 1300
Go to longest playlist which is typically the main movie. You can choose other playlists/titles in the bdlite menu but it will just say Title 1, Title 2, etc... which means you will need to guess
post #724 of 1300
How would the Movie Jukebox be able to make that determination? Supposedly MyMovies has metadata scraping support for Mede8er with their current prerelease which requires use of the jukebox. How would you launch the correct file then.
post #725 of 1300
in the remote theres a option to chose playlist, with more other options, that feature will need to be add along with all the others.
post #726 of 1300
Running the V2 beta now. Installation went without a hitch. Having fun testing files now.
I managed to get the unit placed in an area that receives the remote signal well. It definitely doesn't have the wide range of coverage that some of my hardware does. I can point my tv remote literally behind me towards the back wall and it still receives the signal. But I know all remotes are different, and at least I've got it working now that it's in a better location for it.
Now that the beta V2 is installed, I immediately noticed something very interesting regarding the off-center issue I was having. I'm not sure if I can post about it here though since I'm supposed to keep quiet about the V2 beta results. If I'm told it's okay to post here about what happened with the off-center issue, I'll do so - if not, I'll just post it in the V2 feedback thread over at the Mede8er site.
So far I feel very positive about V2.
post #727 of 1300
Rather than posting this here, you should of ask them on the V2 feedback thread. I don't believe you are suppose to be talking about Beta on here at all.
post #728 of 1300
You're likely correct. That's why I didn't want to mention any details.
post #729 of 1300
Originally Posted by Dean M View Post
I did regenerate the metadata but there is no description. I have a couple of different XML files generated so I wonder if it's getting confused. Which XML file is generated for the mede8er?
Not sure which exact one, but I have a bunch of options set in my movies meta data options like XML, nmj, nfo, med8er, my movies XML. One of them does the trick.
post #730 of 1300
since im Raw beta, i will quote some happy user with news results of beta group v2
I was surprised to see the 23.976 motion bars play back smoothly at 60Hz also
Now, after the V2 beta installation, the image is absolutely, perfectly centered. Several different overscan tests confirm it. And the side-by-side files play perfect now.
post #731 of 1300
I think I get what you're saying... so playing special features aside for a moment, the jukebox knows which file to play for the main title by default and will launch the movie correctly?
post #732 of 1300
i dont no how mymovies app works in dune players
i check the mymovies app for iphone and theres a full remote appication, i guess they will add a playlist option to choose different title.
if the special feature you are refering its the movie extras, since there no java licensed on this players for correct menus , the built in players works by playing the largest files by definition...i think.
if you really care about movie extras, you can use makemkv to extract the correct movie with extras, and you can rename them and put all together in different movie section.
you should try the mymvovies app is very complete with thousands of information per movie, actors profiles , movies clips etc.
post #733 of 1300
For the most part yes, I believe the logic is simply to start playing the longest playlist. If you happen to have 2 main movie playlists (i.e. regular and uncut version with different timestamps, my guess the version with the longest timestamp will play)
post #734 of 1300
Makes sense. Not the most optimal setup but considering I usually watch the main feature 99% of the time in my dedicated room I'm not going to worry about it. I guess my only other concern would 3D blurays with both 2D and 3D selections on the same disc.
Damn Cinavia....
post #735 of 1300
Damn Cinavia....
The 2D/3D discs I have tested it appears the 3D version takes priority
post #736 of 1300
I'm seeing occasional stutters on 2D BDISO files which appear to happen randomly with DTS MA, haven't seen it yet with TrueHD...no problems with DTS/DD either. I don't see anyone else talking about this so it must isolated to my setup? My Synology NAS and MED are connected directly to my router and using SMB. Going to try NFS but would be nice to hear if others are seeing this as well.
post #737 of 1300
Happen to be a Netgear router?
post #738 of 1300
Nope, Linksys WRT310N. I was wondering if there was any router settings to improve things, the only things I came up with through searching were for wireless setups.
post #739 of 1300
I've never tested this myself and I don't believe all routers have the setting available but can you specify the port speed on your router? If so, I've read that matching the port speed to the device resolves this but don't quote me on it. In this case, 1gb instead of auto on the router for the port the med1000 is connected to.
post #740 of 1300
I don't see anywhere I can set this so I guess the answer to that is no.
post #741 of 1300
@dcj1139
Random audio drops its difficult to understand whats the cause.
1)Try a direct connection from synology to x3 if you have spare ethernet port
2) use this settings in x3 udp> 32k
3)use NFS
4) rip The iso to mkv with makemkv for testings only.
5) reinstall fw recovery mode press power button until mede8er logo is gone
6) use cat6
Thats would be 1st steps i would do if its my case.
Edited by canton160 - 12/30/12 at 11:27am
post #742 of 1300
I tried 1, 2, 3, & 5. I didn't have a Cat6 cable to try. Switching to NFS 32k I got my first video stutter a little over an hour in. So I bypassed the router and connected direct and got the stutter at the same exact scene. Thinking it was the file I rewound and it went past the scene without issue, couldn't get it to duplicate.
I think I'm now convinced HD audio isn't worth the hassle. I'd rather miss a few bits of audio that I likely won't know I missed rather than being interrupted with stumbling video.
post #743 of 1300
@dcj11369
Lets forget the network for testing, since is giving mix results.
Try with External/Internal Hard drive only
you mention back there, that exist a random audio drop in Dts-HD.
When you rip your iso to mkv you choose main movie Only i supose, and what type of english audio tracks do you choose? All of them?
What version of makemkv you use? Windows or mac?
What movie titles this drops occours.?
Whats your receiver?
Theres is something in here that is causing this since is random, can be the x3, receiver, or file,
1-test different receiver (same mkv file)
2-test different player (same mkv file)
update: i read in other topic you ripping main movie only , not a clone 1:1 , it was not a bad idea test a full iso clone.
Edited by canton160 - 1/2/13 at 12:03pm
post #744 of 1300
I have setup Yadis on my Windows 7 PC.How do i access it on 600X3D as yADIS does not have export for mede8er?
I have Dune Smart D1 and i use export to Dune in yADIS to save it on Synology NAS. Then i create shortcut to yADIS folder in Dune to access Media library.
post #745 of 1300
yaDIS on the Mede8er does not work like it does on the Dune. Right now all yaDIS does on the Mede8er is gather all the metadata/artwork for the Mede8er to scan
post #746 of 1300
Hi everyone.
I proudly unboxed my 600X3D tonight. Set-up was very simple, but clearly I need to run My Movies to generate xml data since the scan won't pick up my library.
But I ran into one issue that I couldn't yet find in this thread. The image flickers - sometimes every 10 seconds or so, sometimes much more frequently. This does not seem to be the stuttering problem that people mention, since the audio stream still seems to be intact. Plus it happens even in the menu screens without a video streaming. I've tried HDMI Audio and setting to 1080p/60, with no luck. 24Hz setting does nothing. Anyone have any ideas?
post #747 of 1300
Originally Posted by he46570 View Post
Hi everyone.
do you have it connect to tv or amplifier ?
whats the tv model or amplifier ?
try hdmi auto .
also , i advice to try different hdmi input in tv or receiver , looks a hdmi handshake, try to reinstall the firmware to 10.0.5 using the recovery metod with power button.
post #748 of 1300
It's connected directly to the TV via HDMI. TV is a Samsung - I have no problem connecting to a PS3 or WD TV Live. I'll try to reinstall the firmware and try again.
If it is a handshake issue, will that cause total failure or the flickering issue?
post #749 of 1300
try reinstall the firmware
try different hdmi ports
try in different tv.
try component video out
if all that doest change it might be a faulty unit.
post #750 of 1300
Hi everyone.
I had same issue on my system.
I found changing inputs on TV seemed to fix it.
So if you have it connected to hdmi 1, and get flicker, change TV for a few seconds to an unused hdmi port on TV then go back to hdmi 1 to re-lock on.
Also the mede8er is outputting deep color.that might be issue also.
Maybe contact them and see if you can turn it off.
Sent from my SGH-I747M using Tapatalk 2
