Microsoft has pulled the plug on WHS (Windows Home Server Takes It's Final Bow)
From what I understand, WHS was just a stripped down version of Server 2008, but for $50 instead of the ~$400 price tag that Server 2008 carries. If that is the case, and the price is not an issue, should I just use Server 2008, or am I wrong about WHS being a stripped down Server 2008?
I am currently using FreeNAS, and I'm not all that happy with it. I do like the fact that it can run from a flash drive, but I have a stack of SATA drives just sitting here, so putting another drive in the machine really isn't a big deal. I would like to move to a Windows platform for a variety of reasons. Right now I'm just trying to figure out of I should use WHS, Server 2008 R2, or just plain 'ol Windows 7.
This is my hardware setup:
Norco RPC-4220
Supermicro X7SPA-H-D525
4GB Mushkin SO-DIMM DDR3 1333
Corsair TX650 PSU
2x Datoptic SPM94 Port Multiplier
5x WD Green 3TB in RAID5 on one SPM394
5x Seagate XT 3TB in RAID5 on one SPM394
The Port Multipliers allow the 5x drives to be seen by the BIOS/OS as a single 12TB drive (before overhead). So, I essentially have 2x 12Tb drives, that I want to then merge together for one 24TB volume.
So, in addition to which Windows solution, I'm trying to determine the best way to "merge" the drives together. Ideally, I would like to be able to buy a couple more 3TB drives and then add them to the "data pool", and then I'd get another Port Multiplier when I needed to. I wasn't sure if Server 2008 had something I could do that with, or if I should just use FlexRaid's Data Pooling
Thoughts?
Norco RPC-4220
Corsair TX650 PSU
Thoughts?
