I was originally going to try to go with in-wall speakers because I need a very minimal, unobtrusive, slim profile speaker for my front LCRs...
After more investigation, I have too many studs in this particular area of wall, leaving only about 4.5" between them.
This is enough room for Axiom in-wall/on-wall hybrids to fit into the spot, and stick out about 3.5", but they will also look very nice with their cherry finish in my room (we are trying to avoid the shiny high-tech, modern look like the DefTechs have)
However, I've heard some less-than-stellar reviews of the sound quality from the Axioms, so I'm also considering on-wall narrow profile Mythos XTR series.
Anybody have any opinions? And, if so, I have some more DT questions:
1) Is the poor low-end response (92 Hz on the XTR-50) anything to be concerned about? Yes, I will be using a decent subwoofer (leaning toward SVS or Hsu)
2) Does anybody have any comparison information between XTR 40, 50, and 60 models? Right now I can get the 40s for about $370 each, the 50s for about $510 each, and the 60s for $700 each. At those prices, I'm hesitant to go all the way up to the 60s, but also not sure if the 40s are going to be too low-end/
I mean, the bass response is certainly significantly different on the 60s from the 40s...
40 = 100 Hz
50 = 92 Hz
60 = 70 Hz
Are there other significant differences other than that? I was originally leaning toward the 50s, but now it's almost seeming like it would be better to save money and get the 40s, or go all out step on up to the 60s (after all, I saved $1500 by buying a PC instead of a Mac Pro, built to spec using the same components as the Mac... so I suppose that saved money could go into this if I really need it to)
PS. I have a Denon 1612 that I just purchased as receiver, not sure if that makes any difference
40 = 100 Hz
50 = 92 Hz
60 = 70 Hz
