Okay, so it seems pretty overwhelming that SVS and Hsu are two highly recommended subs on this forum. I am not going to start a "which one is better" thread, but rather I am looking for some specifics related to my setup and which would work better as far as lows vs highs, and whether they will be loud enough, or whether ported v. unported or down-firing vs. front is going to be best for me.
My room is about 22' x 13', but the HT is about 13' x 13' square, and I would plan on placing the sub in the front corner about 5' right of the viewing center (projector screen)
I have hardwood (actually softwood - douglas fir) with no subfloor below... underneath is open space (basement)
I will be using Denon 1612 receiver, and my LCRs will most likely be DefTech XTR series (either 40, 50, or 60 -- 60s have down to 70 Hz response, but 50 only goes down to 92 and 40 goes to 100... they are very slim profile, so I assume that's the reason for poor bass response)
Given this is not super low-end bass, my sub will need to handle some mid-level bass in addition to the lowest end. I will mostly be using for home theater, occasionally for music (I'd say maybe 75% of the time will be for HT)
Given this info, which would be best for:
1) SPL
2) Crossover
3) Directionality (downward vs forward -- from what I understand, this can become a factor when you get to the higher frequencies like I would need to cover at about 100 Hz)
PS. I've also considered Outlaw LFM-1 Plus or EX
1) SPL
2) Crossover
