The Pirates of the Caribbean slides for all four movies are finally here!!! The Pirates of the Caribbean series includes a total of 166 slides.
These slides are a part of the HT SlideVision Vol.2 collection. They can be purchased at the following link.
http://www.avsforum.com/t/1424484/ht-slidevision-volume-one-to-be-released-soon
Be sure to read this entire posting since a few things have changed as the project has progressed.
Note that I’m just a Home Theater enthusiast like many of you and not an expert by any means at graphic design or video compilation. That being said I’ve done my best to make everything look and sound as professional as possible. If you do find errors let me know and I will correct them and email you the corrected slide.
In the below postings you will find my entries as I completed each movie’s slide set with a few samples of each set and the exact number and type of slides in that set all totaling 169 slides.
Slides are in JPEG format 1920x1080 as well as in their original paint.net format so anyone can edit them.
Here is just one of the ,MKV files that can be obtained through the HTPC & 100% Playavle DVD versions.
I will include a .TXT file with the links where the free editing software can be downloaded. The applications I used to create these slides are….
Paint.net - for Slide editing & creating
PhotoStory 3 - for compiling the Slides into a video with transitions
AVC - for converting video formats
MKV Merge for combining the 5.1 soundtrack with the video
The collection is sent through the mail on a DVD sorry no download option at this time.
The files on the disc are all in sub folders so you will probably want to re-arrange them on your computer before using them in a Pre-Show
After 3 weeks I have finally finished the Curse of the Black Pearl slides. This includes...
38 Total Slides
3 Quotes
5 Supplemental (Snacks, Food etc)
9(x2) Multiple Choice
6(x2) Q&A
Here are a couple of samples...
Edited by gamephoenix - 2/22/13 at 1:14pm
38 Total Slides
3 Quotes
6(x2) Q&A
