hi everyone , i recently upgraded from a Denon 1912 to a SR7007 , but i have a little problem ,
i connected all my speakers to the 7007 using the same cables that i used for my denon 1912 , got my PC and PS3 connected too , but there's a constant noise sound in the background , like when there's nothing playing there's a constant "shhhhhhhhhhhhhhhhhhhhhhhhhhhhhh" sound , as soon as i turn on the Device , coming out of all the speakers . how do i make this noise stop , didn't have it with my denon
any suggestion would be appreciated
thx
EDIT :
Originally Posted by
DrMichael
Good evening,
I currently own a Marantz SR7007 AVR paired with Martin Logan speakers and have noticed a faint hissing noise when the volume is turned all the way down or when the speaker is not in use. I for sure hear it when I have my ear up to the tweeter. I can hear it at my listening position (8 feet) when I mute it on and off noticing the change. I hear it is normal for a hiss to occur when close to a speaker with hightly efficient/sensitive speakers paired with powerful amps. Any thoughts on this issue? Is this normal?
Thank you
i'm having the exact same problem , a hissss sound from the tweeter , how do i fix this
