AVS › AVS Forum › 3D Central › 3D Source Components › Dialog volume way too low on 3D blu-ray movies - need help
post #1 of 2
I bought a 3D TV a couple of weeks ago (samsung es8000). I discovered that when watching 3D movies on my blu-ray player (Panasonic BDT-210), the dialog volume is extremely too low. I don't know how to fix this because the sound effects are not too low. What settings can i adjust? I have a feeling this problem will exist on other players too?
post #2 of 2
I have that issue too on my player that connected directly to my vizio TV.
In my HT, using a state of the art AVR there is a setting called Dolby Volume that is designed to increase clarity and reduce wide ranges of sound. If you have a problem with a particular movie, turn that on and the voices will expand above the music but it doesn't reduce the impact of certain sound effects. Dolby has a patent on this. It also levels the volume on TV commercials perfectly and I keep it on all the time for my Dish Network DVR.
  Back to Forum: 3D Source Components
