Originally Posted by
Ray77085
There has been talk about it, in the past about the port tube coming loose and the grille pegs falling off. I recommend doing a self repair rather than sending it back. The internal sub is really simple and the port tube can be repaired in 30-min or less.
I don't know if this sub will really, really, really,
be discontinued
NewEgg and Klipsch have a master plan
Here's a link that is almost a year old.
http://www.avsforum.com/t/1375790/klipsch-rw-12d-question/30
Here's how to repair the port if you don't want to send it back.
Un-screw the screws holding the woofer in place. Make sure you don't puncher the woofer cone. Pay attention to the wires + and - terminals when getting the woofer out.
When I repaired the port/baffle on my sub I used Clear Perma Poxy. It set's in 5-min and cures in about 3-hours. About 8.00 bucks for it.
Take some of the 2-part Poxy and mix it together. FOLLOW THE DIRECTIONS when using the POXY and don't get it on your hands.
Apply it around the bottom of the baffle where it connects and or joins and hold it in place for a few mins.
Don't worry about trying to get it all the way around where it connects as you will not be able to reach the very bottom. I used a plastic butter knife to spread it.
It will not come loose again once the POXY dries.
Good Luck
