AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official Bryston SP3 Thread.
The Official Bryston SP3 Thread. - Page 7
post #181 of 1163
Originally Posted by moonhawk View Post
Your SP3 doesn't do any video processing anyway, so why not just bypass it entirely with the HDMI video out from one of your sources? Send the audio to the Bryston.
You can do that easily with the 103, in fact Oppo recommends it.
Ok, that's a thought - but how do we get the audio to the Bryston then? I'll investigate.....
post #182 of 1163
Code:
Originally Posted by Boldlygo View Post
I have discovered one major flaw though - I was trying to play a 3D movie from my OPPO BDP-103 today to my Epson Pro Cinema 6010 through the Bryston and it kept saying I didn't have a 3D display hooked up. Well I actually have 2 displays hooked up - an ND 42" 2D display and the Epson. Unless I disconnect the 2D from the back of the Bryston (in HMDI 2 out) I cannot play 3D movies. Not good! I think Bryston should have made the HDMI outputs selectable to run in either parallel mode or independent mode and allow you to switch between all the settings. It's not good having to unplug a cable every time to watch 3D. Is there another way to do this that I can't figure out?
If you turn off the ND does it still do the same?
post #183 of 1163
Originally Posted by wagnerc View Post
Code:
(ND should have read: HD - it's just a simple Sanyo 42" HDTV)
I had the TV turned off at the time. I use it to watch TV shows and such when I don't feel the need to pull down the screen and turn on the projector. The TV sits on the wall in front of my system and the screen pulls down in front of it. So I have both the TV and the Epson projector plugged in to the SP3 outputs with all my inputs - HD cable, OPPO Bluray, Toshiba HD player and a Sony PS3 plugged in. I simply turned on my OPPO, switched the SP3 to 'DVD' input and tried to play a 3D movie. The movie stopped at a screen and said it needed a 3D set hooked up in order to play 3D. The only way to get the player to continue was to unplug the Sanyo TV from the back of the SP3.
post #184 of 1163
The problem is I need to send video to the projector from many sources - cable, HD-DVD, PS3 and Bluray, including 3D and non-3D. If I plug the projector directly into the OPPO, then I can't watch any of the other sources on the projector.
post #185 of 1163
Originally Posted by adidino View Post
I'll post some impressions soon. I already have a 4k projector (Sony VW1000). I was just curious if anyone has tested it yet.
Tony, I can confidently say that, given your significant experience with top notch prepros, especially the Classe SSP800, you may offer one of the most compelling reviews/comparisons yet. If you dont mind, please don't hesitate to post your impressions as-you-go, as many of us I'm sure are very interested in your opinion. I for one am just about to pull the trigger on either the SSP800 or the Krell S1200, and I'm dying to hear how the SP3 stacked up to the Classe. Thanks much....Jeff
post #186 of 1163
Easy...
HDMI 1 out to your display (from Oppo 103). HDMI 2 out to Bryston. Set Oppo to "Split A/V". cool.gif
post #187 of 1163
OK--If all your sources have to go to both sets, you may need some sort of HDMI splitter.
You might try the Bryston forum on Audio Circle as well. James Tanner is the big cheese at Bryston, and posts there often. It's set up as an online resource for Bryston owners.
post #188 of 1163
Thanks, I'll do that
post #189 of 1163
Well everyone, I just received my new Bryston SP3. Whoohooo!
Having many trials & tribulations setting inputs - I'll work through it, but this is definitely NOT user friendly. This remote is just plain awful. Who puts 4 arrow keys in a straight line?! Can't wait to get a universal remote.
I did some testing for sound and here's what I can report:
I use a computer I built as a music server running iTunes with everything ripped using AIFF. One of the reasons for getting the SP3 was to eliminate other pieces, such as my Ayre K-3x pre, my Marantz AV-7005 and my NAD M-51. Well, this piece does the job of all of those and better. Great, great sound detail and presence in 2-ch and multi-ch sound.
I had the use of a Stello U3 piece and tested the USB out of the computer into the Stello, then into the SP3 using a Coax cable and an AES cable. Sounded pretty good. But then I plugged the USB cable directly into the SP3 and it was just as good, so no need for the Stello. Then, I plugged my trusty Chord optical cable from the PC to the SP3 and it sounded even better! So this is the configuration I'm going to stick with. The optical connection is the best sound I get. (I may have said this before in a previous post, but using the music server blows the doors off playing the CDs directly from any player I have ever tried).
I'll have more discussion later, but time to get some listening in!
For what its worth, I have two 3D Sony blu-rays connected to my SP3, and it plays 3D to my Sony 55HX929 without any problems. But, I loose 2 bits if I connect directly to the television, it displays 12 bits, but through the SP3, it displays 10 bits. Also, for what its worth, I have been really enjoying playing music through the "clouds" using the Amazon air player. The SP3 plays music from the clouds quite well. It sounds very airy with tremendous dynamic range. The high frequency sounds natural without any digital sound at all. With more than 300 CDs having been purchased from Amazon, playing the music random is better than any radio station I've ever heard. Its not a state of the art sound, but its close enough. Its playing back at at sampling rate of 48 as oppose to 44Hz, but I don't know if its 16 or 24 bits. Regardless, it sounds damn good and I find myself listening all the time through my IPad3. The music sounds better than any turntable I have owned, and I've had good cartridges including a Shure V15 type III and a Stanton 880, I believe.
Edited by gbaby - 3/4/13 at 10:40am
post #190 of 1163
Tony, what's up? It's been 5 days already!!!! Inquiring minds want to know biggrin.gif
post #191 of 1163
Boldlygo, what do you use as a server? Everyday PC, or purpose built server?
post #192 of 1163
Waiting for the antimode which actually arrived at my dealer. I plan to pick it up on Saturday. Hang on smile.gif
post #193 of 1163
Tony, you're killing me, lol!!! While we're waiting, since I'm also considering a Classe SSP-800, can you give me a quick synopsis of the SSP-800's sound characteristics for 2 channel music, both as an analog preamp and using it's own dacs? I know you loved this unit and spent quite a bit of time with it. Thanks much...
post #194 of 1163
The Classe did an excellent job for 2 channel music but I wouldn't say it was the end all for 2 channel performance. I've heard better from dedicated 2 channel preamps but my main focus was usually multichannel content anyway so I never really concerned myself with it.
In short, if 2 channel is secondary for you, you can't go wrong with the Classe at all. I will say, so far, the Bryston performs like a high end two channel pre. Very impressive! My initial impressions so far is the SP3 is a music first design. Last I've heard a processor perform this well with 2 channel was the Proceed if anyone remembers that unit.
post #195 of 1163
Thanks Tony. I do remember the Proceed, and how everyone raved about its performance as a preamp. I am a 2 channel guy, with mch music running close second, and movies secondary and not terribly important. I tried the Marantz av8801, figuring that I could add a good 2 ch preamp. However, while good, I was not sufficiently impressed with the marantz in mch music, but I did appreciate the convenience of easy input selection, which made me rethink the 2-box angle. I am now looking for a one-box solution if possible, so was looking for a processor that was close to a good 2 ch preamp, and excellent in mch music as well. Hence the Classe SSP-800, Krell S1200, and Bryston SP3. I had ruled out the Bryston as it has no EQ, it is supposedly not user friendly, it's quirky in operation, and has a useless remote. However, much like Michael Corleone, no matter how hard I try to get away, the great comments about it's sound quality as a preamp keep drawing me back in, lol.
I look forward to your more comprehensive comments about the SP3. If I may trouble you with one last question: is the difference between the 2ch performance of the SSP-800 and the SP3 very significant, or noticeable but not huge? I'm trying to gauge the delta here, and whether it's worth overlooking the SP3's operational issues and lack of EQ I stated above.
Thanks again. Very much appreciated.
post #196 of 1163
2 channel is significantly better over the Classe (so far) but I need to run through some more content. As for no EQ, it's a legitimate concern but in my experience room correction is most effective in the lower frequencies (200hz and below). An external eq like Anti-mode should do the job just fine. Especially for subwoofers. I'll know for sure once I have it setup on Saturday.
Edited by adidino - 3/7/13 at 7:33pm
post #197 of 1163
2 channel is significantly better over the Classe (so far) but I need to run through some more content. As for no EQ, it's a legitimate concern but in my experience room correction is mot effective in the lower frequencies (200hz and below). An external eq like Anti-mode should do the job just fine. Especially for subwoofers. I'll know for sure once I have it setup on Saturday.
Thanks again. Just made my decision process that much harder, lol.
post #198 of 1163
It's never an easy decision but if your priority is stereo, this seems to be the right processor.
post #199 of 1163
Well, as luck would have it, to further complicate matters still, I was just informed I may be able to get a used SSP-800 and Classe CP 800 for little over 8k. So, for close to the price of the Bryston, I get a great prepro and an excellent dedicated 2 channel preamp. I guess if I get a universal remote with macros, I can manage the two box setup without having to manually switch inputs when I want to go in and out of HT Bypass. Man, I need to just pull the trigger on something so I can get on with my life!!!:confused.gif
post #200 of 1163
Hi Tony
To be clear, you're saying you prefer the Bryaton over the Classe for stereo, right? I've never heard the Classse, so I wouldn't know. I do know this SP3 is the sweetest thing I've ever had.
I have an anti-mode, BTW. It does a great job of taming my subs. Of which I just added number three. I managed to locate them all equidistant from my listening spot--not from my wife's, but I doubt she'll care if she ever finds out...eek.gif-- I run all three as mono, set their volumes roughly equal using the Bryston's test tones, then run the SP3 setup for distance and volume, then do the anti-mode.
post #201 of 1163
Hi Tony
Correct. I am looking forward to playing with the Antimode.
post #202 of 1163
And you guys are having no problems with setup quirks, handshakes, and owner manual fuzziness?
post #203 of 1163
The setup itself is pretty straight forward. Some minor quirks navigating through the setup menu but the latest firmware (I just installed it) seemed to correct it. Haven't experienced any handshake issues. Did someone mention handshake issues?
post #204 of 1163
Honestly, I've read so many forums about so many processors, I can't be certain, but I believe there were some issues. Maybe on AudioAfficianado SP3 forum.
Tell you what. I'm seriously mulling over the two box Classe deal, and the SP3 sounds sweet, but if I wind up getting the Krell S1200, maybe I will drive it over to you in NJ and we can compare it to the SP3? I'm in Jersey all the time for business anyway. I've actually talked to two people who had them both (one AA member who compared them directly, and a dealer who did it off memory), and they said they were pretty similar, no huge differences. Classe, as good as it is, seems to be running slightly behind in third place behind these two in terms of 2 ch SQ.
post #205 of 1163
I'm up for that. Let me know.
post #206 of 1163
Will do. But that Classe combo is hard to pass up.......
Edited by jeffkad - 3/8/13 at 7:29am
post #207 of 1163
Antimode?
post #208 of 1163
I, for one, am not having problems with hand shakes. The manual is vague, but you can download a revised manual on Bryston's site. As far as setup quirks, my initial thought was that setup was challenging, but, I later figured everthing out. For one, I figured out that you need to set the crossover frequency, distance, and speaker size for each input you use, and this includes both digital (optical and coaxial) and HDMI. You can only use a total combination of 4 optical or coaxial inputs, but 8 HDMI inputs. If you want to play stereo you hit the stereo button and when you want to go back to multichannel you hit stereo again. If you want to use your analog balanvce input, you hit the balance 1 or 2 input. If you want to bypass the sub on balance, hit the 2 channel button. Its really quite logical, and the beauty of the unit is once configured, you don't have to touch it again.
post #209 of 1163
One minor issue in setup I did stumble into was changing speaker spl test from auto to manual. Stays in auto for some reason and won't let me change it. An thoughts? I must be missing something?
post #210 of 1163
Originally Posted by wse View Post
Antimode?
http://www.dspeaker.com/en/products/20-dual-core.shtml
