AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › NuVo Essentia - want to connect my PC or Mac
post #1 of 4
Hey guys - sorry for the Noob-age.
Bottom line is that I was wondering if any of you have written a plug-in which will permit an instance of iTunes on a Mac or PC to play through the NuVo, and transfer the metadata etc over NuVoNet, so that the track info etc is displayed on the keypads. Bonus points if you can control the iTunes instance via the keypads.
Ideally, we could connect the ethernet port or serial (more likely) as a device onto the all port and go from there...
Any help?
post #2 of 4
The original NuVo Music Port (NV-MP) was exactly this... It's a combination of a NuVoNet adapter (serial to NuVoNet) and the Autonomic Controls Mirage software. No longer sold, but they do pop up on eBay.
Easier to find (and a current, supported product) would be to get just the NuVoNet adapter (NV-NNA) by itself (same adapter, just no software bundle) and buy a copy of CasaTunes - which has very similar functionality. My only gripe with CasaTunes is the lack of native Pandora support, but they do have Airplay support, so you can get there - but without metadata / control. You can also buy a copy of the Mirage software from Autonomic, which does support Pandora, but hasn't been updated in quite a while (as they've been focused on their music server products).
By far the easiest, but more expensive, path is to just get the NuVo MPS4 server (or the Elite, which supports network-shared libraries), which has everything done for you.
Jeff
post #3 of 4
Thanks so much for the tips! It's odd about the lack of Pandora support... still - I'm excited!
Appreciate the assist.
post #4 of 4
  Back to Forum: Home A/V Distribution
