AVS › AVS Forum › Display Devices › Display Calibration › New Apartment Screwed up My LCDs Custom Calibrations! WHY?!! PLEASE HELP!!!
post #1 of 8
So, I just recently moved into a new place, and I just set up my Sharp LCD in my room. When I went to turn it on? It looked great! Though, when I started playing games, and watching Netflix/ movies (I use my Xbox360 for everything)? I started to notice the contrast and brightness were way out of wack!
The contrast was over saturating the whites, and my blacks were so hard/ dense... Thinking, at first, "Oh, my settings must have gotten messed up from unplugging the TV from my old place, and reset to default." I check to see if that was the case? It wasn't!
I'm so confused by this because I calibrated my TV like an art at my previous place. everything looked great at the setting they were at, and now they look like garbage! Not only do I have to drop my contrast ratio, but I also have to raise my brightness up to over the 50% marker! Everything's washed out now! Though, using the calibration tools I have from this site, this is the correct setting its supposed to be at now?! Am I missing something?? I'm at a huge loss here as to why my TV's calibrations are all out of wack!
Is it the voltage coming out of the wall? Did the Xbox360 recently update the Source material for color coding to something outrages now? I'm kind of bummed...
If anyone has an answer, or can at least speculate whats happened? Id love the input!
Thanks you.
Posting my before/ after Custom calibrations and my Sharp LCD model number below:
Sharp Aquos LC-42D64U
Before Custom Calibrations (old house)-
Mode: Dynamic
Backlight: +0
Contrast: 32
Brightness: -1
Color: +0
Tint: -11
Sharpness: -4
Color Temp: Low
Active Contrast: Off
Fine Motion: Off
Film Mode: Off
*NEW* Custom Calibrations (new house)
Mode: Dynamic
Backlight: +0
Contrast: +26
Brightness: +11
Color: +2
Tint: -11
Sharpness: -4
Color Temp: Low
Fine Motion: Off
Film Mode: Off
post #2 of 8
Unless you actually used proper calibration equipment, your tv was only visually changed to your liking in the prev. residence. So looks like you have to go back through your settings and make the basics fit the new place. Has nothing to do with voltage, all it has to do, is with the changes in the menu. In order to do a proper calibration, you have to get into the Service menu to make those changes.
post #3 of 8
It really looks like your video levels changed from video to PC.
I'd suspect a setting in your xbox changed.
post #4 of 8
+1; sounds like the most likely explanation, given that the issue is white level and black level related
post #5 of 8
Lol, yes I'm aware I need to change the settings in the menu. If you read my post it states i did that for the new place. Dur.
See, Thats what i thought too! The xbox settings r all calibrated to there default settings. I dont understand why it has made the black levels so washed out
post #6 of 8
is there a black level setting on the TV as well?
in any case, I'd toggle back and forth between video and PC levels on both devices to see if it reverts back to its correct state (sometimes these controls can be a bit buggy)
post #7 of 8
No, theres just the gimmick "Dynamic Contrast" setting and "film mode". There's no black level like they have on the samsung LCDs.
post #8 of 8
Check your HDMI color space in the XBox.
Sounds like it thinks you're hooked up to a PC rather than a TV. Might want to try RGB.
