AVS › AVS Forum › Video Components › Home Theater Computers › Should i upgrade from Athlon II to G840?
post #1 of 14
I had a bit of luck yesterday, a friend has upgraded his desktop to an i5 CPU and has given me his G840 so this has given me the idea of upgrading my main HTPC from an Athlon II 250. I plan on using a lot of my existing components and just buying an H77 motherboard, what do you think, is it worth doing?
This is what I will have;
Silverstone GD05 case
Silverstone 400 watt PSU
ASRock H77 Pro4-M................. My only new purchase.
Intel G840
Scythe Shuriken Rev B cooler
2*2GB DDR3 1600 RAM
Sapphire HD6570 1GB GPU
Samsung BDROM
Western Digital 320GB HDD 2.5"
I am running Windows7 and XBMC, my media streams from a 2*2TB NAS.
David
Edited by DavidT99 - 7/21/12 at 10:48am
post #2 of 14
The funny thing is that we are at a point in CPU performance that you really don't need the latest CPU anymore. The main improvement you will notice is with the integrated graphics. If you are using descrete graphics you won't see any improvement in media playback.
Unless you know somebody who could benefit from your athlon system I would say its a waist to upgrade. Your graphics card is superior to Intel integrated graphics by the way.
post #3 of 14
My thinking is that the CPU will help with CPU intensive tasks and the GPU will improve on the Intel HD graphics creating the best of both worlds.
David
post #4 of 14
What CPU intensive task? If all you are doing is streaming movies your gpu is doing all the heavy lifting. The radeon you currently use is much more powerful than the intel hd graphics so why would you downgrade that?
post #5 of 14
OP is not planning on downgrading. I believe he only plans on replacing motherboard+CPU. That's it. Personally, I'd be too lazy to do it unless my motherboard doesn't already have USB3.
post #6 of 14
David
The Intel is faster it just doesn't matter much for video playback once you reach a certain level.
post #7 of 14
+1 ( My HTPC is still AMD 7750)
post #8 of 14
My mistake I read it as he wanted to use the intel hd graphics thinking it would be an improvement instead of use the cpu with the radeon.
post #9 of 14
Personally I think you'd be better off the selling the G840 and using the $$$ for an SSD to use with your existing setup......
post #10 of 14
I already have an SSD in my 2nd HTPC and to be honest have noticed only a very small increase in boot time and no difference in day to day use after upgrading from a 2.5" HDD.
David
post #11 of 14
Looks like the general consensus is that upgrading is not worth the hassle so maybe I will just buy a cheaper motherboard and upgrade my desktop which is running on an older Intel C2D E4500.
David
post #12 of 14
By the way I updated my athlon II 250 to a quad core llano and really didn't notice any difference. Since I was using integrated graphics I should have noticed a much bigger difference then you will notice, but nope not really. The main improvement is that I can now send 5.1 audio over HDMI instead of using a separate toslink cable, the fact is I would have been just as happy dropping in a HD6450 discrete card. Oh well, I say don't upgrade any HTPC until it wont do something you want/need.
post #13 of 14
David
With the right graphics card that e4500 also has plenty of horse power for HTPC.
post #14 of 14
I have XBMC loaded on the desktop PC so that I can test plugins before I add them to either of my other HTPC's, the desktop has an Nvidia GT520 gpu installed, I also have a spare AMD HD5450 doing nothing at present.
I also have a Silverstone ML03 HTPC case with a Be Quiet 300watt psu installed, a spare 2.5" HDD and 4GB of DDR3 memory. Almost another HTPC in spare parts.
David
