Hi all. I'm new here and trying to learn while setting up a theater. I did a search and found some good info but I wanted to ask a more specific question(s)
Can I damage 125w speakers with a 250w amp? I assume I can if I get stupid or reckless or suddenly go deaf and crank the volume to the sky. So I'm taking under normal use. I'm also assuming that with 6 Ohm speakers the amp outputs 250w
The speakers are Monitor Audio RX6 & RX Centre and RXFX. Amp Emotiva XPA-5
Also is there a potential problem with the mismatched frequency response? Are there adjustments I can/should make?
I'll be using the Yamaha RX-V1700 preouts for now but plan on moving into a pre/pro in the future (if funds allow).
Any help or advice would be greatly appreciated.
Speaker specs:
RX6
System Format: 2 1/2 Way
Frequency Response: 38Hz - 35kHz
Sensitivity (1W@1M): 90dB
Nominal Impedance: 6 Ohms
Maximum SPL (dBA): 114.8
Power Handling (RMS): 125W
Recommended Amplifier Requirements (RMS): 40-125W
Bass Alignment: Dual Chamber, Bass reflex with differential tuning.
Twin HiVe®II port System
Tweeter Crossover Frequency: LF: 700Hz
MF/HF: 2.7kHz
Drive Unit Complement: 1 x 6" RST® Bass driver.
1 x 6" RST® Bass/Mid driver.
1 x 1" (25mm) C-CAM® gold dome tweeter
External Dimensions:
(H x W x D)
inc. plinth & feet 905 x 275 x 310 mm
(35 5/8 x 10 13/16 x 12 3/16 inch)
Individual Weight: 16.4 Kg (36.13 lb)
RX Centre
Frequency Response: 45Hz - 35kHz
Bass Alignment: Sealed Cabinet
Tweeter Crossover Frequency: LF: 500Hz
MF/HF: 3.0kHz
1 x 6" RST® Bass/Mid driver. 1 x 1" (25mm) C-CAM® gold dome tweeter
Product External Dimensions:
(H x W x D) 185 x 500 x 200 mm
(7 5/16 x 19 11/16 x 7 7/8 inch)
Individual Weight: 9.62 Kg (21.13 lb)
RXFX
System Format: 2 Way
Frequency Response: 60Hz - 35kHz
Sensitivity (1W@1M): 89dB
Maximum SPL (dBA): 111.8
Power Handling (RMS): 80W
Recommended Amplifier Requirements (RMS): 10-80W
Tweeter Crossover Frequency: 2.1kHz
Drive Unit Complement: 1 x 6" RST® Bass/Mid driver.
2 x 1" (25mm) C-CAM® gold dome tweeters
(H x W x D) 250 x 300 x 120 mm
(9 13/16 x 11 13/16 x 4 3/4 inch)
Individual Weight: 4.69 Kg (10.38 lb)
Emotiva XPA-5 Specs:
Number of channels: 5
Signal to Noise Ratio:
1 watt: > 97 dB
Full power: >111 dB
Input impedance:
unbalanced: 23.5 kohms
balanced: 33 kohms
Transformer rating: 1,200VA
Secondary capacitance: 60,000uF
Output devices: 6 per channel
Topology: fully discrete, dual differential, high current, short signal path Class A/B
Power output (all channels driven):
300 watts RMS @ 4 ohm (0.1% THD)
200 watts RMS @ 8 ohm (0.1% THD)
Rated power bandwidth: 20 Hz to 20 kHz with less than .05 dB deviation at rated power
Broadband frequency response (-3 dB): 5Hz to 150kHz
Amplifier gain: 32 dB
Speaker specs:
RX6
MF/HF: 2.7kHz
(H x W x D)
RX Centre
MF/HF: 3.0kHz
RXFX
1 watt: > 97 dB
Full power: >111 dB
Input impedance:
balanced: 33 kohms
