AVS › AVS Forum › Audio › Receivers, Amps, and Processors › No Component out on Denon AVR-3803
post #1 of 8
Hi everyone,
I'm setting up a bunch of video game systems and trying to route as much sound and video as I can through The Beast (my Denon). I'd like the video to be routed through the component out, but I can't seem to get it to send anything to the TV that way. I've played with all the video source settings, but I'm stumped. Halp?
Edited by Dustin Hodge - 7/22/12 at 2:58pm
post #2 of 8
You're referring to the 3803 perhaps? Check the Owner's manual and try resetting the microprocessor.
post #3 of 8
Ugh, what an inauspicious beginning. Yes, the 3803, not the 8303. I don't have a remote control for it - is that going to be a problem? If so, do you know of any universal remotes that will work?
post #4 of 8
Nope. Resetting the microprocessor involves pressing keys on the front panel display. Check your Owner's manual for the procedure.
post #5 of 8
Honestly, I don't think I need to reset the microprocessor yet. I just need to get into the system settings to switch video outs. I've programmed my Comcast universal remote to work with the 3803 (it turns it on/off and adjusts power anyway) but I still can't seem to access the system menu. Pressing "Setup" or "Guide" or "Menu" don't seem to work. Perhaps I'm looking in the wrong place? I'm expecting it to pop up on the 3803's display. I also have a TV hooked up via component out but I don't see anything happen there, either.
post #6 of 8
Although newer models allow menu access from the front panel, the 3803 does not. You'll need the remote.
post #7 of 8
Hah, well, that seems to be a little hard to come by. Any chance at using a universal remote?
post #8 of 8
You might be able to download the remote codes to a Harmony remote from the Logitech website.
