AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Will JVC RS 55 throw a 113 in image (16x9) from 13 feet?
post #1 of 3
Thanks, unfortunately I do not know how to calculate lens throw.
Gear mentioned in this thread:
post #2 of 3
Yes. For further measurements check here:
http://www.projectorcentral.com/JVC-DLA-X70R-projection-calculator-pro.htm
The X70 is the same as the RS55.
post #3 of 3
Is the 113 the screen diag or is it the screen width? Divide your throw distance in inches, here 156, inches by the screen width in inches. If that number lies between 1.4 and 2.8, your in business with the JVC. Regardless, the JVC will work with either size.
