AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › New house Russound Abus - how to stream Pandora?
post #1 of 3
I just bought a house that has a h484 with all zones enabled. At this time I don't think I will need different music in separate areas. So I only plan to use one of the inputs and at a later time I could add some more sources. I do have about a 200 album Itunes library but mostly want to stream Pandora. Just wondering what would be the best way to get Pandora as a source. I was thinking that I would use a Sonos connect as the easiest and cleanest way but wondered if anyone has any other suggestions that might work.
post #2 of 3
Since you mentioned Itunes, I am assuming you have ipod, iphone, ipad or some set of apple devices. I think iphone/ipod will always have the best set of apps for streaming/consuming music (pandora/spotify/etc), so I am planning on using AirPlay from my devices to stream my distributed audio. Buying a $99 airport express (https://www.apple.com/airportexpress/#airplay) and plugging it into whatever you use to distribute audio should work pretty well assuming you've embraced apple products.
post #3 of 3
Thanks but it seems like the sonos software is better from my reading. I got a sonos for droid and apple support.
  Back to Forum: Home A/V Distribution
