I bought this receiver because of its wireless capabilities.
Overall I am happy with my purchase but there are some issues:
1. The HDMI pass through seems to be hit & miss. When the unit is in standby the TV will find the video signal from my cable box some of the time, but not all of the time. There are times when I have to turn on the receiver in order for the TV to receive the video signal from the cable box.
2. Airplay is also a hit & miss situation, unlike Bluetooth which seems to work flawlessly. When Airplay works its great, but many times the connection doesn't happen.
3. I’m not sure why the receiver seems to default to the TV input. I’m not even sure why the TV input comes up all together. The HDMI is connected to the sat/cable input, there is nothing connected to a TV input.
4. Important info like sound settings are only readable by getting very close to the receiver display and taking note of the small icons indicating the current mode. My older Sony AVR had a big blue light that would come on when the receiver was playing in a digital mode.
5. This last issue just started after ten days of using the receiver. For some strange reason now, whenever I try to go to the “GAME” input (PS3 through HDMI), I have to continuously keep pressing and holding down the GAME input button on the remote, as if to force the receiver to let me go there. If I just press normally it defaults back to that mysterious TV input.
Overall the this is a very impressive piece of tech for the price, but I would like these issues resolved.
UPDATE:
It seems that most of the issues I am having with this receiver stem from connection problems.
As for the "TV" input I discussed previously, I now understand that whenever a desired connection (airplay, game, etc...) is not completed, the receiver defaults to "TV". I still haven't discovered why this happens, but I do see a pattern.
NEW UPDATE:
After using this receiver for over a month now I am overall still very happy with it.
Once you learn its quirks, you adapt to them and start to understand the technology more.
The remaining issues still pertain to connection problems, but it remains a very impressive piece of tech.
Edited by bramg - 1/14/13 at 7:01am
UPDATE:
NEW UPDATE:
). And do you have any insight into what is causing this change in video quality? It has to be something in the Receiver, since that's the only thing that has been added to the equation. Is there some way to have the receiver process the audio part of my xbox's output while telling it to leave the video signal alone? Honestly, I'm a little annoyed that this is even an issue, as one of the main purposes of getting a receiver (other than its necessity to power my speakers) was that everything could be piped through it and handled and adjusted through a single interface.
