AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › help samsung ln46a530 distorted right side of screen
post #1 of 6
hi my samsung LCD screen sometimes gets distorted on the right side of the screen
i have had it for about 4 years anyone happen to know what is wrong? is there anything i can do to fix this or do I need to call a repair man to fix this?
post #2 of 6
nobody has had this type of problem?
post #3 of 6
Check the link for more info, but 1/2 screen issues are usually TAB related.
http://www.lcdparts.net/howto/symptom.aspx
post #4 of 6
excuse my ignorance but what is TAB?
this video clip is an example of what my screen does sometimes
http://www.youtube.com/watch?v=H9iuJUKzuH4
post #5 of 6
Sorry, I am not a repair person. My knowledge of TABs is the same as yours. I'm sure you can find info with some searches as TAB problems are often mentioned here, Samsung has had many people complain about it's failure. You might call their CS number and see if they are doing anything about the issue. Otherwise, searching will provide you with more info. Look thru this site for the owner's thread on your exact model and you might be able to find out more info that way as well.
post #6 of 6
Thank you i will look into it
