AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › Connecting a cable box to a pdp-433cmx cable box
post #1 of 4
I've got a pioneer pdp-433cmx plasma TV and was wondering how I set it up to a regular cable box. Thanks!
-Bob
post #2 of 4
There were no instructions on how to hook it up? I would think you could just run a coax from the cable box to the CATV/Antenna coax input on the tv, and set the tv to cable.
post #3 of 4
I am not sure what a "regular cable box" is but if it has composite or HDMI outputs I would use them to the TV since you can then send HD content instead of coax since the signals oiver coax are normally in NTSC SD fornmat.
post #4 of 4
What type of connections does your 433CMX have?
What type of connections does your "regular cable box" have?
