AVS › AVS Forum › Audio › Receivers, Amps, and Processors › wish the denon 1912 was a 7.2 instead of a 7.1
post #1 of 17
i really like the denon 1912 over the onkyo 609 due to the better audyssey, but i like the onkyo 609s dual sub out. my room is about 13x16x8, but will have 2 short hallways connected to it. i just ordered the klipsch rw-12d for the sub. is there a denon receiver comparable to the denon 1912 with a 7.2 instead of the 7.1 that isnt a lot more money?
post #2 of 17
http://www.amazon.com/C2G-Cables-40650-Female-Adapter/dp/B000M52X62/ref=pd_cp_e_0
attach this to the sub out on the 1912. problem solved. Most 7.2 receivers just split the .1 signal to another subwoofer.
post #3 of 17
wow, its that easy?
i guess it makes sense. i was thinking you couldnt do that for ohm reasons, but the subs are powered on their own so i guess the receiver just sends the pre amplified signal? thanks
post #4 of 17
Correct. Until you get to the higher models that use Audyssey MultEQ XT32 w/Sub EQ HT (ie. 4311CI), dual sub pre-outs (ie. 2312CI and 3312CI) use nothing more than an internal "Y" splitter.
For more information on your 1912, join us in the Denon AVR-XX12 Owner's thread linked in my sig. Review posts 3-6 in that thread for additional helpful setup and troubleshooting information.
post #5 of 17
ok, so just to be clear, the audyssey that comes on the 1912 will still work properly to tune the subs and speakers even WITH a y splitter on the back?
thanks
post #6 of 17
just read the thread on the xx12, very helpful. sounds like the 2112 would be ideal for me, but seems to be sold out most places, so i will just order the 1912, see how one sub works for my room, then if it is inadequate ill get the splitter and 2nd sub later. thanks for the help.
post #7 of 17
thanks
Yes, as is the case with any version offered on Denon AVRs. Review the Audyssey Setup Guide linked in my sig for special circumstances regarding dual subs.
I would call around to all authorized resellers (to include AVS Sales) as the 2112CI is a much better buy than the 1912 as it offers a 3rd year of warranty and the higher version of Audyssey MultEQ XT.
post #8 of 17
I do not understand. Why is the 2112 any more "ideal" for you than the 1912? A least as far as the calibration of dual subs are concerned? Perhaps now the XT is the hook?
Limited availability on the 2112? :http://www.amazon.com/Denon-AVR2112CI-Integrated-Surround-Receiver/dp/B004Z0S7OM
James
Edited by mastermaybe - 7/24/12 at 7:40am
post #9 of 17
post #10 of 17
James
with regard to single vs dual subs, there is not difference to me. i was referring to how the 2112 has combined the XT version of audyssey with some nice features like network connectivity, etc.
post #11 of 17
jdsmoothie,
thanks, i will check around at my local best buys and see what they have. another option is to get the 1712 with the XT audyssey but lose out on some pretty nice features that i would like to have, like a usb, airplay, pandora, network connectivity, etc. but then again, i can get lots of apps on my new tv. but these features would be nice on the receiver as well. ill look at bb for some 2112's, otherwise i will get a 1912. i would like the XT version of audyssey, but its not a complete deal breaker. im sure the multieq will be fine for me.
post #12 of 17
Agreed. With no prior experience with Audyssey, the MultEQ version in the 1912 will still perform quite well indeed. smile.gif
My point was that, as the 2112CI is generally offered at the same price or maybe $50 more in many cases, if you don't mind doing a little calling around to locate one of the few remaining 2112CI units, it would be worth the effort.
post #13 of 17
i understand, but my plan is to buy refurbished, and the only place that i know of that offers is refurbished is out of stock. if i was planning to buy brand new, then i would call around. so, i understand what you mean, but refurbished is def cheaper
post #14 of 17
Originally Posted by jdsmoothie View Post
Ummmm, well seeing YOU never stated or implied such, but the OP DID, why would you assume that I was referring to you? wink.gif
James
post #15 of 17
Sorry, my mistake then ... thought you were responding to my post. redface.gif
post #16 of 17
James
post #17 of 17
just ordered a refurb denon 2112 for 350$
