AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Sony VW 60 turns on inconsistently
post #1 of 4
When the lamp does ignite, it looks fine. But it doesn't ignite regularly now.
The fan comes on. I bought it at AVS in 07. It's been a good performer. I am really not ready to upgrade.
The lamp is pretty new.. The ballast? What are my options for service? Southern Califrornia
Thanks gents.
post #2 of 4
Sounds like the ballast or some part of the power supply. Usually lamps are a go or no-go. Once in a while as they are getting old you might find this happens, but from the sound of your description it seems to be fairly regular.
post #3 of 4
Thanks. Am looking into Sony service center locations here.
I doubt I will try to replace the ballast myself.
Thanks again
post #4 of 4
Welcome. It is probably best to be safe. Plus it may not need a full replacement, it could be way more simple (bad resistor, lose connection, etc...). Better to start small.
