AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › What change in eyeglass prescription is significant i.e should I get new lenses?
post #1 of 7
I recently had a vision check and what is a relatively light, under 2 diopter, prescription has changed 0.25 for one eye. Anyone know if it is enough to make significant improvement and thus make it worthwhile to get new lenses?
Dave
post #2 of 7
Dave,
Which eye had the change? Is it your dominant eye? Nearsighted or farsighted? What shape are your glasses in?
In general, I would tell a patient that it's not enough of a change to warrant changing glasses.
Jeff
post #3 of 7
A 0.25 change is usually not enough to warrant new lenses
post #4 of 7
Thanks guys. I p.m..'ed Jeff with details since thread was moving away from generalized advice.
post #5 of 7
If you're talking nearsightedness, if you're under corrected by a 1/4 diopter your far point is at 4 meters, the additional correction would push you out to infinity. It may be noticeable at night. It depends on how high your correction is to begin with. A 1/4 D change would be more noticeable to someone who's only a -.25 to begin with vs someone who's already a -12.
post #6 of 7
Dominant eye od, nearsighted. Glasses in good shape verilux physic enhanced.
old od S -1.00 Cyl -0.75 Axis 70 new -1.25/-0.50 axis 64
os -.05/sph new -.05/-.025/085
post #7 of 7
Negligible change in spherical equivalent, you have to take into account the change in astigmatism. Unlikely to be noticeable.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
