I looking to upgrade from a Mirage s12, must be a noticeable step up from the Mirage...
70% movies/30% music, rest of system Dynaudio Focus series
Mirage specs:
Front-Firing Subwoofer / Bass Reflex With Two Downward-Firing Ports
1200 Watts Peak Power, 300 Watts Continuous
Woofer: 12" Polypropylene Titanium Deposit Hybrid With Ribbed Elliptical Surround™
Voice Coil Diameter: 2"
Maximum Driver Excursion: 1.61" Peak-To-Peak
Frequency Response: 19Hz-120Hz +/- 3dB
Phase Switch; 0/180 Degrees
Variable Low Pass Filter: 40Hz-120Hz @ 18dB/Octave
Inputs: Low Level, Stereo High Level (Speaker Level)
Crossover Filter Switch: On/Off
looking to spend under $1k...
thanks!
Mirage specs:
thanks!
