AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Sim2 HTLink 300 -> Bulb going off
post #1 of 6
I am having a couple problems with my Sim2 HT 300 Link (early version, not E).
The first one has been going on pretty much since new, although quite a lot more frequent now. I can turn it on, via remote control, and it may start up OK; it may come on upside down with a green cast; or it may start, but not stay on long enough to show a picture, and shut off. Light on the processor remains green as if it thinks it is still working OK. Turn off/back on at processor, and it usually comes on OK. Its getting to where I have to do that a copule times.
But the more pressing problem is that now, it will just turn off the bulb after watching for a while. Fan going in unit, but goes off. Again, to get it going, turn off/back on at the processor.
Anyone have any ideas about what might be wrong?
post #2 of 6
On the first one...does the lamp have any light coming out (even if you look in the lens)?
post #3 of 6
On the first one: When I first turn it on, and watch the bulb:
Success if in about 5 seconds after turning on, the bulb turns a quite red color. The screen often comes on upside down, then inverts
Failure if it does not turn red. It comes on for 10-15 seconds then completely goes out. The controller has flashing blue and solid green light.
post #4 of 6
Sounds like it is not the lamp, but the main board honestly. It can be fixed, but, realistically it is not going to be worth it. Last I checked that was a ~$1500 fix or so.
post #5 of 6
Thanks. I had decided to not bother trying to fix.
Friday, I purchased an Epson 5910e, and am enjoying it now.
Thanks for the input.
post #6 of 6
You are welcome. Probably a better bet in the long run.
