AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › BIGmouthinDC - Summer Fun, Just 10 minutes down the Parkway
BIGmouthinDC - Summer Fun, Just 10 minutes down the Parkway - Page 7
post #181 of 209
The artsy fartsy part is 14 inches. Then there is an inch something black border.
post #182 of 209
Jeff, does the layout look familiar? I relied heavily on the basic layout from your place except no false wall for the screen, Just not enough room.
On the HVLP sprayer it worked like a champ the beauty is that there are very few parts to clean, no hose to clean. The overspray was minimal and I just sprayed them all on my workbench with a sheet of plastic. My problem was all those nooks and crannies that would have been impossible with a brush required quite of few turns of each piece and a lot of angling of the gun to shoot into every corner, But it worked and I'm going to keep in in my truck.
Yes it does look familiar. Brandon actually said that prior to me commenting. I have considered a HVLP for all the reasons you mentioned. If you want to stop by and help me finish on your way let me know. Chris says she will cook!!
post #183 of 209
Originally Posted by cdika17 View Post
Is the carpet, Platinum Plus Wondrous from HD?
Yay or nay?
post #184 of 209
It was from a local carpet store, I think it was a Shaw carpet. If it is critical I can stop in when I get home the end of the month.
post #185 of 209
No worries, pretty sure its the one and also the one ill be using! smile.gif
post #186 of 209
Big - Are these the Utilitech Accent 4" lights? if so - what bulbs are you using in these and are they OK to install in MDF soffits?
post #187 of 209
I used 35 watt frosted GU10 bulbs on the perimeter but upped it to 50 over the screen in the 4 inch Utilitech cans. The picture you posted is a 4 inch Halo can with regular Edison base blubs I used those over the seating. I think I used 65 watt in those , can't remember.
Edited by BIGmouthinDC - 11/5/12 at 4:11am
post #188 of 209
Well I have my design from the Erskine Group - I keep coming back to this thread - I really like the look of the theater.
Couple more questions - what is the ceiling height in this room? In particular - the screen wall?
Also - what speakers did you end up going with?
Jim
post #189 of 209
I forgot to mention that I often hang a blind in the closed position so it looks 100% natural on the outside. If you ever want to open it up and re-purpose the room the framing is in place.
I have black out window tint on my two windows in the theater. Then plugged and buried. Works well too.
post #190 of 209
What step light did you use, where did you get them. Lowes or HD only has outdoor deck step lights.
post #191 of 209
Ally from memory they are Royal Pacific step lights from Wayfair. basically a Christmas light bulb holder that fits in a single gang box. Comes with both covers, vertical and horizontal. Does not give off a lot of light if that is what you are looking for.
Back on my laptop and found the link
http://www.wayfair.com/Royal-Pacific-Mini-Step-Light-in-White-8905WH-RYP2559.html
Edited by BIGmouthinDC - 12/8/12 at 3:59pm
post #192 of 209
Big - what was the ceiling height in this room?
Jim
post #193 of 209
From memory, 7-10
post #194 of 209
Thanks Big
post #195 of 209
quote]
Big - Couple questions - I am assuming that is MDF on the lower part of the wall painted black? What is the height of these wood panels?
Now the panels that get installed above this area - I believe you said they are ~20" high?
Jim
post #196 of 209
BIG:
Just wanted to thank you for the step light link. I just received my shipment of them yesterday. They are great and you can't beat the price. AVS needs to start a thread where these great finds and deals can be posted/listed.
post #197 of 209
Jim just eyeball it, I don't remember but they had to be taller than the top of the existing outlets.
post #198 of 209
Amazing thread. A bit curious how you connected the rope lights. Light switch to a switched receptacle enclosed in the larger soffit. Yes?
post #199 of 209
No, hard wired
post #200 of 209
Another Great build and very impressive. I am wondering though, I see so many of these builds that get finished and I am sure that they sound great. However, few people discuss just how well they have managed to keep sound inside their home theater. Big can you comment on some of the builds that you have done? Obviously you are comfortable in your sound proofing approach as you use a similar approach on most of your builds, but how much sound is usually heard upstairs in these builds? I am still kicking around building under the bedrooms or on the other side of the house.
post #201 of 209
No, hard wired
Excellent. THANK YOU!
post #202 of 209
was working on the pilasters for the room today and should have done soon, then some Final Pictures. Until then here is the basic layout and the most recent shots I have on my camera
BIG,
Isn't 11.5' from screen to first row a little too close, how was the experience in first row? Also, with just 23' length, the bar section in back must be just 5 feet, wonder if that would fit any stools. And if this layout did work then this is very optimal utilization of space.
Awesome work!
post #203 of 209
Originally Posted by anubis05 View Post
BIG,
Awesome work!
In my 1st HT, I was 10' away from a 100" diagonal 16:9 screen, and both me & my wife feels like we could go for a 110" especially for scope movies. Therefore, I would say 11.5' for a 116" diagonal 16:9 screen is a pretty good size for both movie & TV/sports. But again, everyone's preference & vision is difference tho. cool.gif
post #204 of 209
Today I went over to install the pilasters and a cabinet for storage (unfinished oak from Lowes stained black). and my SUMMER FUN is over.
Some FINAL PICTURES in no particular order.]
I know the build has been complete for a couple months but just had to reply. I love the design details on this one, especially the wooden art pieces on the walls and the double light tray.
Also love the traditional color scheme. Everything just seems to mesh on this build. Very professional. Another BIG Build to add to my idea archive.
post #205 of 209
Thanks landshark1.
This forum and especially BIG's theater build threads are inspiring me to get something nice done myself. I am still in process of absorbing all the knowledge in this forum.
post #206 of 209
I'm 11ft away from eye to 175" scope screen (6ft height IIRC). No way too close for me. I think some viewers want another foot or two though.
There is no better konwledge than making mistakes. I have redone my theater 2 or 3 times already, I demolished my basement and I'm working from scratch now. You will make mistakes. Stop reading and start hammering.
post #207 of 209
Gary
post #208 of 209
Beautiful build Mr. Big.
Love the bevel where the seams of the red panels come together and your pilaster design is amazing. Yet another build that I will shamelessly steal some ideas from wink.gif
post #209 of 209
Thanks, steal away. That's how I come up with all my ideas.
