AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Running a receiver temporarily without a subwoofer
post #1 of 2
Hello folks,
The situation is: friend has a TX-NR709 but no subwoofer yet. I'm flying over to set up his home theater on Saturday. Polk Monitor 70's for L & R, and smaller Polk speakers elsewhere in a 5.1 or possibly 5.1+heights setup. Well, it would be .1 except for the subwoofer lacking.
My question is: what can I expect from this in the short-term? Will the lack of a subwoofer basically suck the amplifier dry in the TX-NR709, as it tries to fill that role with the floor-standing Monitor 70's? What effect will this have on maximum volume level? Will loud/bass-rich parts of the movie trip the receiver over into current-limiting (4ohm resistance?) mode? I'm aware that the calibration process will set the L/R speakers to "Large" when there's no subwoofer, ergo all of the above.
I've never tried such a setup before, as I know the general rule is -- you just do not do this. I need to know what to expect in the short-term. In the medium-term, he will get a subwoofer, and I'll make sure that he knows how to calibrate properly so that when he gets it, he can recalibrate efficaciously.
Thank you for any wisdom you can impart.
post #2 of 2
Correct ... the AVR will be limited in max volume level (more so than with a sub); however, the Polk 70's are 8-ohm, 90db efficiency speakers so fairly easy to drive and therefore a max volume level limitation may not impact your friend as most folks listen well below really loud "reference" volumes.
