AVS › AVS Forum › Audio › Speakers › Which of these speaker systems should I choose?
post #1 of 3
I'm helping a friend decide on an entry level home theater system for $500 for the speakers/sub and have narrowed it down to this list. Which of these are the best of is there another I should consider (I'd ideally not like to hear more since I'm trying to narrow down the list, but if it is really worth mentioning then give it a go...
In no particular order:
  • Klipsch HD 500 5.1 High Definition Theater system
  • Pioneer SP-BS41-LR Speaker System
  • Energy 5.1 Take Classic Home Theater System
  • Definitive Technology ProCinema 600 5.1 Speaker System (this may be a stretch $ wise though so unless it is really that much better)
Thanks in advance!
Edited by avfanatic1 - 7/25/12 at 5:34pm
post #2 of 3
Check out Frys Electronics website, gobs of Polk deals and some of those are for sure not "entry level" which makes the score that much better!
Brian in Bakersfield...
post #3 of 3
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981013
i have no experience with this set, but for $299, i'd get it over any other HTIB out there.
+Buy a $200-33 receiver like the Pioneer VSX-1022 (thats what i got for 300) but theres many options out there.
  Back to Forum: Speakers
