AVS › AVS Forum › Display Devices › CRT Projectors › Screen size
Screen size
post #1 of 2
Testing a 6pg xtra that has like new tubes in it with a Moome unit. I have CIH screen that measures 120" wide and has a gain of 1.5 in a light controlled dedicated room.
Will this projector be able to fill this screen with good results?
post #2 of 2
120" Wide screens are usually not recomended for CRT...The projector may fill the screen but most likely it will be dim.
You will be driving the projector hard and the new tubes will be old tubes really fast.
92" to 100" (diagnal) screens are the norm for CRT projectors especially 7" Models
  Back to Forum: CRT Projectors
