AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Integra Dtr 7.9
Integra Dtr 7.9
post #1 of 6
How do you disable Dolby Digital on a DTR 7.9? Thanks
post #2 of 6
Simple. Do not input a Dolby Digital format signal.
AJ
post #3 of 6
in my other outputs it is not on. How do I disable it?
post #4 of 6
Why? Dolby Digital decoding is automatic. It is required with Dolby Digital format signals and is disabled with other format signals.
AJ
post #5 of 6
ok because i thought i hit something on the tuner and messed it up. So dolby digital is automatic?
post #6 of 6
No, the FM tuner and Dolby Digital are completely unrelated.
AJ
