OK, so here's my setup:
As you can see, there is very little room under the TV on the first shelf of the stand, for speakers. I currently am using the speaker set from an Onkyo HT-S5400, with the Onkyo 609 as the receiver. The onkyo center channel fits because it uses 3 1/2" drivers and the cabinet is barely 5" tall. Total clearance under the TV is between 5 3/4 and 6 inches. I can't set the speaker in front of the TV because it blocks the TV's IR sensor for the remote.
I'm looking at these two center channels for upgrade:
Polk CS10
BIC America DV-62CLRS
First question, which would you get? Second, would it be a bad idea to place the center channel above the panel, mounted to the wall and telescoping out and angled down towards the listening area? Or should I try and make a rig to lift the panel up higher on the stand? The stand is a Walker/Edison 4 in 1.
Could I maybe just get an IR blaster of some type and just sit the bigger speaker in front of the TV on the shelf? That would probably be the most ghetto version...
At this time, mounting the panel to the wall is not an option.
Any adivce is appreciated!
Edited by mfrey0118 - 8/20/12 at 6:10am
Polk CS10
