I have 4 zones of speakers and 1 zone of 2.1 channel audio to a tv. Each zone has a simple volume control, the 2.1 audio is controlled through a IR using a denon remote/direct tv remote for the receiver in a closet. I don't have cat 5 from the volume controls to the main, only two pair speaker wire. Is there something I can do that would allow simple source control and on/off at each zone? Everything I have looked at requires cat 5.
As others have noted, I find that I don't use my system as much because you have to go to the central source to make any changes.
Thanks for your suggestions.
The ability to name the sources on the keypad (from a predefined list, but a good one) makes it easy for guests to use. And it looks cool.
