I have a Roku2XS streaming media box connected directly to a Denon 2310CI AVR thru HDMI.When i stream a movie from Netflix w/5.1 Dolby Digital Plus there is no audio,but the video is ok. I have checked the settings on the AVR and they're set properly to receive and decode DD.+.so i don't 'think' the problem is with the AVR,but still can't totally rule it out. It seems that the AVR is trying to decode the audio,but the audio signal keeps wavering back and forth between PCM and "unknown signal".When it wavers to PCM the blue HD audio light comes on and the 5 input channels(FL,FR,RL,RR,C) light up like it's receiving the signal and ready to decode,but it only lasts for about ~1-2 tenths of a second before wavering back to "unknown signal",then the HD audio light goes out and the 5 input channels disappear.The problem may be with the Roku,and am in contact with Roku support.They're trying to help.
Now i'm wondering about the HDMI cable.All my cables are standard speed,the oldest from 2006.Most of them have double Ferrite cores(one on each end),but the oldest (2006) 4FT.in length has no ferrite core.I've tried swapping diff.cables but that makes no diff. i still have the same problem,and am wondering if the cable(s) are not quite up to the task of delivering DD+ even tho' they are only 4 FT.long.So my question is:Do i need to buy a high speed HDMI cable to get the DD+ audio???? Thanks in advance for any help. G.
Edited by greaser - 7/26/12 at 3:03pm
