Originally Posted by
AJinFLA
I would suspect most (AVSers) are concerned mainly with
living rooms, not
control rooms, which are quite separate situations, despite what Studiophiles may believe.
No. It's all about the
acoustic source room interaction. Never heard a "room" produce sound other than AC noise myself.
You mean "various" different monopole after monopole after monopole interacted modally with the room? Well, yeah...
cheers,
AJ
No, the audio fundamentals, ... too few have any idea what's going on electronically, or acoustically.
The control room info is just a bonus if you want to read it.
I realize you feel the room isn't of significance, and it is amazing how much we "hear past", but the room is dominant wrt the bottom end.
Due to a discussion between Winer, Erskine, and myself, ... wrt Toole's findings, ...I took down all my treatment a year or so ago, plunged head first into
my room, and my LP. There is a better way than no treatment in
my room. I've manipulated every parameter I can, mains type, mfr, location, sidewall prox, distance, angle, ....with and without scattering, absorption @ ceiling, wall, front and side, ... I've done the legwork, as each system/room requires it's own approach.
Everybody wants immediate answers though, ...what do I do?
