AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Small or Large....speakers
Small or Large....speakers - Page 2
post #31 of 34
Originally Posted by kiwi2 View Post
AJ tries to make out that his speakers aren't affected by room modes...
Only in your buywire imagination.
... but yet won't publish a frequency response graph that isn't either cut off at 200hz or smoothed and manipulated to look flat at a quick glance..
post #32 of 34
So you think your speakers wouldn't be affected/influenced below 100hz by the same room that the shootout was performed in?
Why are you arguing against the valid point FOH was trying to make?
Hey, leave my girlfriend out of this!
post #33 of 34
So you think my dipole (subwoofers) would be affected/influenced below 100hz similarly by the same room that the shootout was performed in?
So you think my cardioid (subwoofers) would be affected/influenced below 100hz similarly by the same room that the shootout was performed in?
So you think my linear quadrupole (subwoofers) would be affected/influenced below 100hz similarly by the same room that the shootout was performed in?
So you think rotation in various axes of each of the above would be affected/influenced below 100hz similarly by the same room that the shootout was performed in?
Or because it could be misconstrued.
(Response) It's the room/source type interaction, dependent upon where source type is spatially + orientation, etc.
Is that what he said?
post #34 of 34
You'd need bigger wellies than most kiwis for that, and the expression would have to change to "You can lead a buck tooth wide eyed horse to a cliff..."
