AVS › AVS Forum › Audio › DIY Speakers and Subs › Center speaker as Ipad\multimedia speaker
post #1 of 4
I was thinking of a lepai amp along withe the Sony ss-cn5000 center speaker, would this work? I suppose you would lose stereo.
post #2 of 4
Yes stereo would be lost and you would need some way to sum the stereo channels or else you will be listening to only one channel. Does not seem worth it. Are you 'thinking' this because you already possess these items? Go for it if it really costs you nothing. If not, for the same money you could buy this Yamaha soundbar which will likely do what you want: http://www.walmart.com/ip/Yamaha-Sound-Bar/20713576
post #3 of 4
if you have the items, set the iPOD to MONO (if it has that capability), if you dont have the items, go for powered PC speakers or the lepai with some smaller bookshelve speakers from Craigslist.
post #4 of 4
True - I have a pair of Creative Gigaworks speakers and they really rock. Shocking quality, deep bass, even flawless stereo imaging! http://www.amazon.com/dp/B001S14DYO/?tag=hyprod-20&hvadid=15473202699&hvpos=1o2&hvexid=&hvnetw=g&hvrand=569836980632511090&hvpone=&hvptwo=&hvqmt=&ref=asc_df_B001S14DYO
