AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Problem with my Samsung UN55D8000 Need Help
post #1 of 11
First off, I have contacted Samsung and they are sending out a technician in 1 - 2 days to look at my TV.
I'd figure I should still post on here to see if anyone else has experienced this problem. Look at the photo below, I turned my TV on last night and saw this. I've never ever had a problem with my TV until last night. You'll notice in the photo that the bottom half of the screen is darker then the top. This is consistant on every channel, and even on other input such as Xbox and BlueRay.
post #2 of 11
Hey I have the same tv and lately have been experiencing the same problem intermittently. If I turn off the tv and turn it back on, it goes away. Let let me know what the technician diagnosis is.
post #3 of 11
Same problem here only the line on mine is a bit lower. Any answer from Samsung? My tv is just Orr a year old and just out of warranty so hoping its an easy fix.
post #4 of 11
Is it me or do Samsung TVs have a lot of reported issues, especially when the 1 year warranty expires. Don't get me wrong, I do like the way their TVs look on and off (except for their edge-lit models), but their reliability is questionable and customer service lacking.
post #5 of 11
Hey,
I know this was posted a while ago but hopefully this goes to your email and I get a quick reply. I have the samsung un55d8000. I purchased it almost a year and a half ago. Last weekend the SAME thing that happened with your TV is happening with mine! I called samsung and they said wait a week see if it still happens then they will send someone over to see whats going on. So I was wondering what happened with your situation? Did they come to fix it? Was it an easy fix? What was the reason for this and did they charge you? What was going on?? Please get back to me and let me know. HOPEFULLY you get this!!
post #6 of 11
We have the same thing happening intermittently on our 1-year old 8000. It's almost an even split on the screen so a little lower than the picture.
Just like other posts, turning the TV on and off corrects the problem. I haven't been able to identify a sequence or media type that consistently causes the problem.
Please let us know if you got any resolution from Samsung. Like others, I'm out of warranty.
post #7 of 11
If you are close to the one year time period for the warranty, if you register your product they are extending the warranty for 3 months.
post #8 of 11
I registered and it extended it by 3-months.
The tech is coming out this afternoon to look at it. My son snapped an image, which shows the line a little lower than the first post. The good thing about this image is that it was generated from the SMARTHUB so I won't be getting any run-around that my cables or other AV sources are the problem.
IMG950782.jpg 269k .jpg file
post #9 of 11
Our Samsung just started doing the exact same thing and we are out of warranty. Has anyone gotten a response as to what the problem might be?
post #10 of 11
Hopefully this will answer some questions.
The Tech came out in early December saw the problems (I had taken pictures) and said that it was probably the T-Con board. This board supposedly controls the timing and lighting of the TV.
The same tech came back out on 12/20/12 and replaced the T-Con board and the flat cable inside the TV. The tech said if that didn't fix it, there wasn't much else to replace other than the panel.
So he leaves and about 30 minutes later it happens again and actually starts ghosting on the right side of the TV as well. As a result, I start running all of the tests and taking all of the pictures that the tech said he would need to request a new panel. I communicate with the tech that afternoon and he uploads all of the new pictures up to my case.
Here's where it gets fun...
My TV went out of warranty on 1/8/13. I didn't think it would matter since the first repair was initiated under warranty. Well emailed the tech on 1/15/13 and all he said was that they denied the panel replacement. While I was really ticked off that the tech didn't call or e-mail me the denial while the TV was still under warranty, I tried to keep my cool and I'm glad I did.
This started multiple chats with Samsung, which were cumulatively more than 4 hours. After telling my story in more than a half a dozen chats and being told the problem had been resolved (every time), I was able to get them to authorize the parts and labor "out of warranty". However, the last chat consisted of me on the phone with the tech, telling me exactly what to type in the chat window.
I found out during the final chat with the tech on the phone with me that while the service center can authorize the parts and labor, I found out that only the engineering area can authorize the shipment of a panel (isn't this a part?). As a result, the tech had to call Samsung directly after all of my chats. I was assured that it had to be the tech, I couldn't call the engineers myself. All of the sudden, keeping my cool and not losing it on the tech when he didn't tell me the panel was denied worked in my favor.
The tech ended up spending another 30 minutes on the phone with Samsung but finally got the panel authorized and they are coming out tomorrow to replace it.
Here's my advice to anyone else who tries.
1. Always register your TV, it gives you and extra 3-month warranty. My original went out in October.
2. Establish a case on line with Samsung. You can upload pictures, receipts and describe the problem. This is the only way to get the process started and it's pretty painless.
3. Always give your case number at the start of the chat. they can pull it up and review it.
4. Always cut and paste all of your chats to WORD or some other pad. These chats also have a reference number that can be given at the start of your next chat and reviewed by the agent (trust me, it's going to take more than one). This will save you a ton of time so you don't have to re-explain it every time it doesn't get resolved.
5. Establish a relationship with your tech and send them the transcript of every chat you have. I honestly could not have gotten it done without their help and in the end, if you require a panel replacement, they are the ones that will have to push it through Samsung engineering.
After all of this, at this point, I still don't know if the panel replacement is going to fix the problem. You're probably wondering (I know I am) why didn't Samsung just replace the TV, this has got to be costing them more.
I hope this helps somebody else.
post #11 of 11
This is the exact problem I had with my UN55D8000 that I purchased 2 years ago. When I initially called Samsung they said since it was out of warranty I would have to get the TV serviced myself. I went to the local Samsung "approved" service center and they said this problem is actually common. This partial display problem corrected itself as the TV warmed up. They suggested I contact Samsung again and take it a level up which worked. The gave me a "one time" service call and repair. They ended up replacing the entire display which I was very pleased about. When you spend this much on a TV you expect to get more than two years of service from it. Well, I'm dissapointed again. The "new" display is two weeks old and has failed. The picture is lacking red and has a blue outline around contrasting features. I called the service center back and they said the replacement display is covered for 90 days. Looks like I'll get a third display for my Samsung which I hope will be the last for a long time. This doesn't bode well for Samsung quality however. At least they are standing behind their product up to this point. UN55D8000 display.JPG 1795k .JPG file
