This Classified is Closed
For Sale:
Definitive Technology Ceiling/Wall UIW BPZ/A Speakers (pair)
Will Ship To: Contiguous 48 States
These have been SOLD - thank you
Selling a pair of NEW Def Tech UIW BPZ/A ceiling/wall speakers. Each has dual 6.5" speakers as can be seen in the pictures below.
Never installed them just because I hesitated to cut the ceiling for too long. I am going a different route now with my home theater so here they are for sale.
These speakers are new but the outside of the box has seen better days. Also the top foam inside the box is deteriorating from the times I've opened/closed the box to remove and show the speakers. Other than that the speakers are new. Grills are there as well as the Manual and a template.
If you would like additional pictures or have any questions please feel free to contact me.
Price is $475 plus ground shipping anywhere in the contiguous 48 states. For your reference my eBay ID is frank75fl and I accept paypal.
Thank you
Here are some specs I found online:
UIW BPZ/A :Specifications
Outer Flange Dimensions | Metric :8-1/2” W x 14-3/4” H | 21.6 x 37.5 cm
Cut Out Dimensions | Metric : 7-7/16” W x 13-5/8” H | 18.9 x 34.6 cm
Depth from Flange | Metric : 3-3/4” | 9.5 cm
Driver Complement :Two 1" pure aluminum dome tweeters coaxially mounted in two 6-1/2" cast-basket bass/midrange drivers
Frequency Response :26 Hz – 30 kHz
Impedance : Compatible with 8 Ohm outputs
Recommended Associated Amplifier Power :10 – 300 watts
A/V Receiver Crossover Setting :40 Hz
Inputs: One pair of gold plated spring loaded posts
Available Finishes : Paintable White
Accessories : Cut-out template
Weight | Metric :lbs | kg
Packaging :Two to a carton
Edited by Sabu-Agu - 9/6/12 at 4:32pm
Thank you
