My wife and I recently bought our first home. We don't take possession for another couple of weeks and as you might imagine, we can barely contain our excitement. I've been dreaming about building a proper listening room (for my 2 channel rig) and a dedicated theatre for many years, so I'm quite pleased that the new house has space to accommodate for both.
The current owner partially finished the basement so my first job will be to "gut" it. The work was poor and the layout is not desirable. I will also need to re-locate a largish HVAC trunk that currently runs the length of the theatre space.
I'm not a super handy guy so I will rely on pros for anything I am uncomfortable doing. That being said, the dozens and dozens of construction threads here on AVS have given me a solid understanding of the best practices and techniques required for the job; I hope to tackle quite a bit myself.
I visited the house a few weeks ago and took detailed measurements of the basement and compared them with the plans I was able to source from the builder. The house is 8 years old and while the builder is still offering this model, I wanted to make sure the plans I was given matched that of my place. Luckily they did.
Here is the proposed new layout of the basement:
Room Details:
Goals:
Gear:
My initial ideas:
Sketch-up file: Theatre Layout - Jul 28.zip 437k .zip file
I've taken ideas from many of the build threads here on AVS but I'd very much welcome any suggestions or comments you may have.
Room Details:
- 14'w x 23'd x 7.5'h
- Located in basement
- A separate equipment room will be located behind the screen wall.
- No windows
Goals:
- Purpose built theatre for movies and occasional TV
- Clean, elegant design
- 7.1 setup
- Seating 5 in 2 rows (Berkline or similar recliners)
- Hidden speakers
- 2:35 or CIH AT Screen
- Carpeted floor
- Fabric Walls
- Lighting (5-6 zones) controlled by a Graphik Eye setup
Gear:
- Projector: ???? In the current design with the projector on the back wall I'd need a throw of about 19.5 feet
- Speakers: I'll probably use a set of Active Genelec monitors I have sitting around for LCR and in-wall speakers for surrounds (Triad, Atlantic Technology etc)
- Subs: Stereo subs behind AT Screen.
- Pre-Pro: Bryston SP2 or SP3 (Canuck eh?)
- Amps for Rear Surrounds: 2 x Bryston 4B
- Sources: Boxee Box, Sony Blu-ray, Cable box
- Screen: Some sort of DIY AT screen -- perhaps I'll buy a frame? Seems easier than building one.
My initial ideas:
