Could the stack be cut when it comes down through the first floor, then a long sweep elbow installed so it was pointing toward the foundation, then a short sweep against the foundation pointing down.. that would bring the piping into the joist bay until it was against the foundation. You could then maneuver over to the hub at the floor.
Is that vertical 2" pipe just connecting back into the 3" horizontal at the ceiling? If so, it serves no purpose and can be eliminated.
Lastly, the sewage ejector piping should not be run under the electric panel like that. No piping can be run under the panel. The pit itself looks like it's in the dedicated panelboard space, but there's no easy way to fix that.
