I told the cs guy that it made no sense at all that low-res files wouldn't play. He put me on hold while he went and talked to someone else, and came back with the absolute that I had to install Jriver software and enable the USBDAC in it's settings. I said that was hard to understand, and that I thought that if my computer would play the file - I should be able to listen to it over USB if installed correctly. I brought up some of the other players that would support high resolution files just so he'd have the info. I knew it made no sense, but it was clear that I was not going to get any other advice.
It is tough to do the install on my HTPC input if I have the Pioneer on the USB input. I think I might run a 25 foot USB from my desktop and have it be the my Stereo center, and my HTPC be more of a visual HDMI party music center. It has BX8a speakers, and they are not kind to most files I've listened to anyways. I thought the stereo music from the laptop was very full and rich over USB (other than the pops and cracks that showed up on every song at times )-: I felt the Bass was very good compared with my Denon, I would absolutely always select DPLII or Neo6 sound over stereo on my 4308, but the stereo sound on the Pioneer 68 filled the large room and even the rest of the house with no problem. I kept telling family -"And this is only stereo - isn't it amazing!" I always felt that my old Pioneer 49 was great at creating a big enveloping sound that wasn't harsh or fatiguing, and the 68 seems to have similar qualities and power, despite being half the weight. I'm hoping it won't heat up the room in the summer as well.
I feel the MCACC did a great job of setting up the speaker levels as well, and it also straight out told me to turn my 15inch200w sub level down to about 30%. I enjoy the little help scripts that the Pioneer gives at the bottom of most every screen - they are very handy! I watched "Trouble With The Curve" on blu-ray, and everything sounded very smooth and natural, with the dialogue perfectly blended in yet clear at low volumes. I was concerned about leaving behind the upgraded Audyssey on my Denon, but I don't really see any reason to worry.
He spent > 1 hr with me on phone calls trying to figure out why it didn't work but in the end it was the OS. Audyssey never thought to test it on XP tablet OS. first time I ever had a USB device not work on any PC no matter what the OS was but it happened
