We were doing some sound comparisions with oppo BDP-105 using oppo"s analog out puts yesterday. With SC-68. They both sound great and both have their own charactors to it. I didnt compare their usb dac inputs yet. Oppo sounded just perfect on two channels stereo out puts but sc-68 had more percise tight control over acoustics but also we bit warm but refined. Thats may be that oppo has about 50 hours of playing time and sc-68 had no more than 4 hours. Oppo was very warm in those early hours. Therefore i think it is a base less comparison at this stage?
On the picture quality: cant see any difference between oppo, pioneer and straight out of motorola 3510m cable box on a 40" sony xbr tv. But when projected on a 150" screen then i have to say that oppo is better. No matter how you play with the settings, oppo makes the picture more refined. I dont know what they have done to the settings. We tried comparing the picture quality with onkyo tx-nr818 which has a descent chip but lower price point. Pioneer is much better than onkyo in picture quality but oppo comes out better in making picture less washed out and showed more depth. We watched in our family room which is not the best place for a projector.
All of the above is very subjective to our opinion. ( dont want any broken hearts LoL).
Now there is an issue that i need help with. I have purchased small speakers with the specks as follows.. I have to say for the price, these are amazong for medium size room and you can mount em upside down if your mounting them over 6 feet high because of their design. And they fill the room just great for me and they disapear physically and sound wise. pioneer just sounds great except one issue.
My automatic setup has setup the speakers at small sub=yes and crossover at 100hz. I can tell that i am missing some sounds inbetween at these settings. Can barely hear NFL reff and some other sounds in documentry. Setup has recognized 5.1 speakers setup just fine. Bass sounds good but its short at either end, not sure front or tail of the bass sound.
Next cross over option in SC-68 is 150hz. The manufacturer of these 5.1 speakers set advises crossover 120.
Satellite speakers:
Omnipolar technology creates a larger, more realistic soundstage
frequency response: 110-20,000 Hz (±3dB)
each handles up to 100 watts
sensitivity: 87 dB
3/4" PTH™ tweeter
2-3/4" Titanium Deposit Hybrid polypropylene woofer
wall-mounting brackets included
binding posts
4-1/4"W x 6"H x 4-3/4"D
Nanosat S8 subwoofer:
bass-reflex (ported) design
frequency response: 33-120 Hz
75-watt RMS amplifier
8" down-firing woofer with Ribbed Elliptical Surround™
12-1/4"W x 13-3/4"H x 13-1/2"D
Thank you in advance.
And thank you jbwitt for you suggetion on Remote control and i will look in to it.
Kris
Edited by FlatRocky - 1/21/13 at 8:06am
Satellite speakers:
sensitivity: 87 dB
3/4" PTH™ tweeter
binding posts
Kris
