AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official Pioneer SC-68/67 Thread
Official Pioneer SC-68/67 Thread - Page 33
post #961 of 1503
Originally Posted by oztech View Post
Unless something changed overnight the OTA output on every TV as been optical or RCA besides the internal speakers ARC has always been for the source connected via HDMI since the tuner is built in the TV and is not tied to the source not happening.
Thanks. Sounds like I will be buying a longer DO cable. What exactly is the use of arc? For example I could take a ps3 and hook it to the tv via HDMI and then output the audio via the receiver by arc? In that case you'd just hook the ps3 to the receiver directly I'd imagine
post #962 of 1503
Originally Posted by zachman View Post
Anybody using the arc feature on their SC-68? I have a Samsung PN60E8000 tv and have enabled the arc function on the SC-68. If I look at the tv input on the SC-68 menu it shows the audio as arc. However when I switch the tv to OTA channel and the SC-68 to tv I hear no sound. Originally I had the tv hooked to the 68 via digital optical and I got sound. My digital cable really isn't long enough so was hoping to use the arc function. Any ideas?
zachman, have you completed the setup? If not, see page 70 of the manual for setting up.
Note: My TV does not support ARC but investigated just few days ago.
Just read that you enabled on SC-68. Ignore my message.
post #963 of 1503
I used ARC previously, and the primary benefit was you could watch the TV with sound from the TV speakers without engaging the full sound from the receiver. With this setup, it was easy for the family to watch TV late at night with low volume levels, and I didn't have to teach them how to navigate the receiver settings. I routed the cable box HDMI directly to the TV, and then connected the TV to the receiver through the ARC slot.
post #964 of 1503
I'm trying to accomplish the same thing but did it through HDMI passthrough....
I route the cable box to the receiver and have the receiver set to passthrough that input to the TV. When the receiver is on standby, the TV gets that signal.
I guess both methods accomplish the same thing?
post #965 of 1503
Sounds like it does. In fact, your option is probably better because the audio is routed directly to the receiver when you choose to use it vs. being routed through the TV. My understanding is that the TV's ARC is limited in the quality of audio signal that goes back to the AVR. My solution was used so that the default setup was TV only and my family members didn't need to understand/manage the AVR or its settings.
post #966 of 1503
Before I understood about passthrough, I was going to do exactly like you said.
The passthrough seemed to be what I wanted. I'm happy with the solution so far.
post #967 of 1503
Thanks for the tip! I was wondering how to accomplish passthrough.
Your tip helped me accomplish.
post #968 of 1503
That's a first for me. I'm always the one asking for help
post #969 of 1503
Not sure if anyone is interested but I changed my 67 to the 68. A lot of you gave good advise and I realize that probably not worth it as I won't need the or use the DAC but I guess I'm stubborn, lol.
I guess its my mental satisfaction and peace. Haven't taken it out will do it this weekend😉
post #970 of 1503
I haven't tried ARC yet but now you have my interest just to see how it works!
post #971 of 1503
congratulations!
post #972 of 1503
Originally Posted by spongebob View Post
So, how does the 68 compare to the Denon 5805 in terms of punch and raw power? I'm still stunned when I go to my folks house and feel the power from the 5805.
bob
Hi bob
yeah, the 5805 was a beast! I've never heard the 5805 but I think the 5805 was what Pioneer had in mind as their target when SC-09 came out wink.gif
I suspect & based on some old reviews that no, the SC-68 won't have the total power capacity of the 5805 or the SC-09. keep in mind, you're comparing totally different animals - the SC09 had a 1400 watt power supply & the Denon 5805's was probably at least that much, I think they claimed max current draw was something like 13 amps, so that would make it ~1500 watts. The power supply in the SC-68 is about 800 watts, IIRC.
those uber-flagships could hit 200 or more watts per, depending on how many channels driven at once. the SC-09 could do 7 x 200 & I suspect the 5805 was similar.
so, how do the new ones stack up? pretty darn good actually. early on, I ran mine with no ext amps for the fronts, just to see how it would handle 5 - 4 ohm Magnepans. I cranked volume pretty high, -8 to -2 dB IIRC, and it never shutdown nor sounded strained, any more different sounding than the SC-09 did or with the ext amp. and this was with fronts set as large. it was punchy, dynamic, not much different sounding to my ears than my 2 ch ext amp, rated @ 300 wpc 8 ohm & 500+ wpc 4 ohm, class A/B btw. to be fair, I compared with some music I typically use for sharp transient percussion, & not movies with loud LFE. nor did I have all 9 channels playing. I was listening to couple of 2 ch & a 5.1 ch music discs (Brothers in Arms, Fagen's Morph the Cat for its very low bass)
so all I can say is - it's pretty powerful but...it'd be hard to say it would "beat" your folk's 5805 wink.gif the 5805 had 10 amps & the SC-68/67 has 9 but the 5805's power supply is almost twice as big but even that isn't a true comparison since the Denon was class A/B at ~50% efficient while class D amps are 80-90%. so the Denon would need a much larger pwr supply wink.gif
I think a fairer comparison is the SC-09 since it's also class D with 2 x the power supply wink.gif and the SC-68 stacked up pretty well. but if you check reviews of the SC-09, SC-57 & SC-68, you'll the see that the SC-09 amps still measured as more powerful, even though the rating is the same smile.gif
that doesn't mean it's not going to work as well for a normal HT system. and let's be honest, both the 5805 & SC-09 were 2.5 times the price of the SC-68. not even Denon's replacement for the 5805, the 5308, was the same in power output. those were unique receivers wink.gif
IMO, the SC-68/67 are as close as your going to get in a modern AVR to those uber-flagships. not even the new Denon 4520 can maintain its power rating 5 & 7 ch driven based on a German YouTube review I came across, where the SC-68, 4520 & Onkyo 5010 were reviewed, compared & bench tested. I can post the link but the translation is pretty rough. I think I can upload a screenshot from it with the power comparisons tho.
I'll do that sometime today.
Edited by ss9001 - 1/25/13 at 9:01am
post #973 of 1503
iControlAV for Android
I know that several of you have had great success with this app on your IPad. I was wondering if anyone has used the Android version? From the reviews on Google Play it appears to be very much a work in progress.
Still waiting for my 67; my dealer had a damaged box arrive on the pallet, and he is still waiting for a replacement.
post #974 of 1503
Yes I have been using IControlAV2012 with Sc-67 on both Android and iOS.
I could not able to power up the receiver with these apps but could able to do lot other things.
Do you have any questions?
post #975 of 1503
I am seeking input as to two channel setups with sc-68. Im still experimenting and feel 2 channel music is lagging, and either adding a 2 channel preamp with passthroough, or integrated amp or dac with direct preamp like the nad m-51. Has anyone done the same or contemplating it and the results?
post #976 of 1503
Just wondering if it's worth the effort, or just stick with my Harmony One for control. Was just wondering what Android users thought of it; nothing specific as I haven't got the receiver from my dealer yet.
post #977 of 1503
I would say app is pretty slick gives lot of control. That is being said, I don't have Harmony and can't compare the both. I am curios to hear experience with Harmony One.
post #978 of 1503
Originally Posted by ss9001 View Post
Pure Direct on a 2 channel source = no bass to the sub
Can I use the Front Preout instead to connect to the sub LFE Line Level In if I can manually adjust crossover and volume on the sub?
Does master volume control work on preouts?
Edited by soniky - 1/25/13 at 9:58am
post #979 of 1503
I use the Harmony One simply because it controls all of my AV equipment but I have used the apps available for a couple of pieces on my iPhone and iPad at times its nice having both.
post #980 of 1503
I've got an SC-1526 (I think it's a rebadged SC-55) & it doesn't output info like surround mode or DRC over HDMI, so I have to look at the receiver to check. I'm told the apps show this info, so when I put my equipment in a closet, I'll have to buy an iPod. Since I don't want to have to keep putting down my Harmone One & picking up the iPod, I'm going to look into remote control apps like iRule. I don't know if the new models show this info. If mine did, I'd just stick with the Harmony.
post #981 of 1503
they do, by app or by remote. at least these SC models do.
post #982 of 1503
hmm, I think I understand what you mean...connecting preamp outs to the sub, then from the sub to the front l/r speakers? if that's it, I think so, using the sub's own crossover for what goes to the front l/r speakers.
you'd have to consult the manual for the subwoofer on the various hookup schemes but using preamp out's to sub line level in's is one way. you'd probably have to set the receiver up differently, I'm thinking fronts to Large, No Sub, so its crossover is ignored completely. I admit I've never used sub this way. but it is the way my speaker company, Magnepan, recommends for their bass limited centers, so that the fronts get the bass, then the sub gets what it's set for, and the center & surrounds get sent to the fronts & sub. SC-57 owner purdyD has his set up that way.
another way could be to connect the sub to the fronts, speaker level connection, and use sub's (I think its low pass crossover) to remove all the freq's except the bass. I tend to get low pass & high pass filters confused so you should check out which one is correct for the connection scheme you want to do. I'm not certain if the receiver's crossover is low pass or high pass & Pioneer has never spelled it out. I usually have to do some reading & checking the terminology in other company's manuals to think it through.
from wiki
Low Pass Filter - A low-pass filter is an electronic filter that passes low-frequency signals and attenuates (reduces the amplitude of) signals with frequencies higher than the cutoff frequency
High Pass Filter - A high-pass filter (HPF) is an electronic filter that passes high-frequency signals but attenuates (reduces the amplitude of) signals with frequencies lower than the cutoff frequency
Master volume control on preamps >> yes, it changes the preamp output voltage so it can control what would go to an ext amp.
post #983 of 1503
Not that complicated. I was not thinking of affecting the two front speakers. I thought they just connect normally to sc-68 but at the same time I can use the front preout to the sub. I thought preouts are always "hot" or is it not true?
post #984 of 1503
This is how I remember these:
LPF = if lower than this then pass. So, if LPF = 80hz, then you get to hear anything lower than 80hz.
HPF = if higher than this then pass. So, if HPF = 800hz, then you get to hear anything higher than 800hz.
So, if HPF=80hz and LPF=800hz, then you get to hear anything from 80hz to 800hz.
I hope I got it right.
post #985 of 1503
congratulations!
LOL Thanks, it stretched my budget as I have a solid amp for 2 channel, 68 will only be used for HT
post #986 of 1503
ss9001,
I need your help.
Been trying to get a gauge on the SOUND of the SC-68. My frame of reference is Harmon Kardon. I have had the AVR 85 and currently the AVR 7200. I've had the 7200 for quite a while now and the sound is actually pretty good. The problem is it's old school and the HDMI stuff is non-existent.
So...I keep reading about this new Pioneer. I want it, but the fear you hear is because of a recent experience I had with Emotiva. I ordered the XPA-5 @ 200wpc and WAS NOT HAPPY AT ALL.
Thin sound. No soulfulness, not warm. 200wpc? Well maybe so, but probably only with some dude in a white coat in a lab.
Tell me about the SC-68. I have Magnepan MMG up front. with Oppo 93
MJ
post #987 of 1503
Looking at the block diagram for the SC-57 (same basic layout as 68), the preamp board has connections to both the amps & preamp outputs so I think you're right, they'd be hot all the time.
post #988 of 1503
MJ
well, I'm a maggie user for many years & have used the Ice amp based SC-09 and the SC-68. not sure how "warm" is "warm" but I think the sound is consistent with my former Pioneer flagships with class A/B amps, the 49txi & 59txi. there's 1 or 2 who disagree and have stayed with the 59txi even tho it's at least 8 yrs old now IIRC. I also have an Innersound amp made by Coda that's class A/B and very hi powered amp made to drive e-stats.
Emotiva: this could end up being controversial biggrin.gif
edit - I removed most of my comments on the XPA5. It just isn't relevant to your question and all it does is foment arguments tongue.gif I'm not dissing the XPA-5 per se, is an OK amp for its price. but it would not find a place in my setup. the XPA-1, 2, and XPR-5 are a different story. I fully accept that those meet & maintain their rated power wink.gif I think you know where I'm coming from.
the SC-68 should hold its rated power up to 5 channels, then will naturally drop. keep in mind it has a 810 watt power supply, but that is class D so being 80-90% efficient, it should have the reserve to be very dynamic. but in comparison with the Denon 4520, a german reviewer who bench tested both, showed the Denon dropping drastically off to only 35 watts per ch at 7 channels. the limits of the power supply start to come into play.
H-K: I haven't had good luck with the 2 Harmon-Kardon products I owned a long time ago. both receivers had quality problems, one required lengthy stays in the repair shop & one was DOA! so I've had no interest in 40 years to own another one. I can't give you a comparison redface.gif supposedly H-K is noted for conservative rated amps, a "warm" sound and having a form of Logic 7 surround processing which many Lexicon owners highly valued smile.gif
there have been a number of maggie owners using the class D SC models over the past 5 years but I can't recall names.
for the record, I have 3.6's, CC3 & MC1 for surrounds. the 3.6's are on the ext amp because they do sound their best and best dynamics the more power you feed them. but I have driven them with the SC-09 & tried out the SC-68 on them and was pleased with the sound. the SC-68 held up very well smile.gif
I don't think the SC-68 will have any trouble powering your MMG''s & be able to give you decent dynamic peaks. but you'll be using a sub anyway so I'd definitely set your MMG's as small, probably use 80 hz crossover.
if you were happy with the power of the H-K's by themselves, you should be with the 68's power.
what you might be noticing as "warm" may not be the amp but how H-K does room EQ. in this, you'll have to draw your own conclusion based on listening to a SC-68 with Pioneer's MCACC room EQ system. I've been happy with it with maggies for going on 10 years now. and if you'd like a bit extra warmth, you can tweak the 125, 250 hz bands to taste. I always felt my sound had body in the mid-bass, low mid-range areas (warmth) and didn't sound "lean". some attribute an edge to hi-freqs to class D design but I have no idea. I can say that all class D amps have the characteristic that distortion starts to rise in the high freqs > about 10-15K, but it's still well within low levels & is a gentle rise until you reach the clipping point. bench tests on the SC-57, the 1st with Pioneer's new class D design, actually showed lower & flatter distortion levels than the previous Icepower amps they used. the switching power supply in the new design is pulsed at about 500-600 Khz while the Ice amps were about 50-60Khz. just like oversampling a digital recording, faster power pulsing probably does = smoother sound.
and this is very subjective but to my ears, the SC-68 did seem to have just a bit less "edge" to the sound than the Ice amps in the SC-09 did, fuller, more rounded sounding. it reminded me of my class A/B Innersound amp smile.gif but I think the difference in how Air Studios tuned each design plays a role. all this is definitely not scientific or objectivist wink.gif just an opinion, consider it like all others....fwiw, ymmv smile.gif
there are a number of MUG forum members who have used the big maggies with class D amps from D-Sonics, Wyred4Sound, Gilmore Raptors. but these are more powerful amps, being based on the 250, 500, & even 1000 watt Ice amps: http://www.integracoustics.com/MUG/MUG/
my best advice is go take a listen. also you may want to PM forum member purdyd. he also uses maggies with his SC-57 and is also happy with his sound.
Edited by ss9001 - 1/25/13 at 2:19pm
post #989 of 1503
And you didn’t waste any of your time writing.
Hmm. Well at some point I’ll just have to take a chance, and make sure I know the return and/or money back rules.
In my area (Denver, CO) metro, there are only Best Buy stores that carry the SC-68. And I’ll probably have to look for even them. Most just carry the lower ones.
None-the-less, my point is that unless a audio product is very poor, you cannot spend near enough time in a store doing worthwhile listening. They either have it setup improperly or a very inexperienced sales person trying to tell you about details he/she doesn’t even know about themselves.
Things are different now. So reliance on forums, and other Internet readings is paramount.
Like I said, I have gotten to this fork because my HK 7200 is yesteryear in terms of inputs/outputs, USB, airplay, HDMI and the sort.
My initial go for was (might still be?) the Arcam AVR600. it retails for about $6, 000 and you have a very tough time finding it for under $5,500. That’s a lot of dough.
But I was ready to eat crackers and water for a couple of months and go for it.
Then I read the article in Home Theater about the SC-68 and began to waffle.
Thanks, I’ll just have to keep reading!
post #990 of 1503
Wow! After much digging...
I found this review of the Pioneer Elite SC-57 and it contained EXACTLY the language I was looking for.
http://www.digitaltrends.com/receivers-separates-amps-reviews/pioneer-elite-sc-57-review/
It’s a couple of steps behind the SC-68 but the reviewer told me just what I wanted to hear.
Great review also.
As Soon As I’m able I’ll be making that move. Then I’ll give much feedback.
