I have an issue trying to setup a local network for my brother to play his media around the house.
A summary of his setup:
-HTPC with 2 external drives attached with his movies (next project is setting up an unraid server for his media)
-The external hard drives are setup as network drives
-HTPC is networked wirelessly to his router (802.11n)
-Laptop is also on the same router wirelessly (also 802.11n)
He is able to access these drives on his laptop but it is very slow and will not play properly. If he copies the files to his laptop from the network drives (which are those external hard drives) it copies at around 2 MB/s. If I look at the wireless settings the Laptop is transmitting at the speed of ~150 Mbps and the desktop is ~30 Mbps. He does not have the option of having either computer wired to the router.
I'm trying to troubleshoot where the bottleneck is that is not letting him play bluray movies smoothly. Is it the host computer with the external networked drives, the router, or the laptop? Is 30 Mbps sufficient for playing 1080p movies across the network?
