I bought an Onkyo S6200 a few years back and had been very happy with it. Recently got married, moved, and the wife doesn't want a rug in front of the tv to put the rear speaker wires under. She, being a wife, is happy with the TVs built in speakers. I, being a musician, am not.
Especially when you touch on the videogame issue and not knowing where sounds are coming from. Not that I need to sell any of you to the horrors of tv speakers.
So here are my options:
1) Is there a way to modify the system so that the rear speakers can be wireless, or (preferably) some add-on I can buy?
2) If not, is there a way to configure the receiver to be 2.1 or 3.1? (A simple "Yes, read the manual" will do)
Cheers and appreciate all responses in advance.
Moe
Moe
). I've also never really delved into all the ins and outs of HD audio. So I just need a few points along the way. A transmitting device that works with my current setup is exactly what I'm looking for. I'm aware it would need its own power supply and that wires would have to be used to connect to the transmitter/receiver.
