This is a 4-channel rack-mount amplifier, 250 watts per channel 8-ohm / 400 watt per channel 4-ohm / bridged pairs 800 watt per channel into 8 ohm.
Full power is rated at <0.01% THD @ 1kHz, <0.05% THD 20 Hz-20 kHz, and for typical operating levels it's <0.01% across the spectrum. With a 106dB signal to noise ratio, the signal is clean and quiet whether the volume is high or low.
(The QSC site has all the specs here.)
To estimate shipping by UPS, the package is 25#, 8x20x22.
Edited by daveidmx - 8/19/12 at 12:44pm
